Will these find their way into our bigger boats?
  • Make-a-Wake
    FE Rules!
    • 5557
    Hmmm, 300 amps, dual cooling fans, 15s capable.................maybe a little water cooling mod on it......etc..................has possibilities. With the twin cooling fans, it may not even need water cooling for a 5-7 minute run............check out all the caps on both ends.
    http://www.hobbyking.com/hobbyking/s...15S_OPTO_.html
  • ron1950
    • 3024
    at 316 dollars ill let u test it out for me carl......
    • Make-a-Wake
      FE Rules!
      • 5557
      Drops just a bit to $299 when added to cart..................
      • Make-a-Wake
        FE Rules!
        • 5557
        Wow, this ESC is 8" x 4" x 2"!! It has at least 10 caps from what i can see and Dual 10g batt wire leads.
        • Diesel6401
          Memento Vivere
          • 4204
          That looks interesting. Maybe worth a shot, waterproofing that thing is gonna be the real trick. The programming card and wires looks like the esc maybe a Hifei to me...Just a guess.
          - Diesel's Youtube
          - Diesel's Fleet
          • sailr
            • Nov 2007
            • 6927
            If it's good quality, it's a lot cheapoer than a Schulze!!
            Mini Cat Racing USA
            www.minicatracingusa.com
            • Make-a-Wake
              FE Rules!
              • 5557
              I run the SF240hv's and they arent waterproof worth a crap anyway so my boats are watertight as a rule......................i'm real close to pullin' the trigger on one, i'd run it in my 47" Kevlar mono and prop up to an x460/3 from a 457/3 to see what she'll do..............
              • Make-a-Wake
                FE Rules!
                • 5557
                I just checked the weight conversion and its almost 2 lbs!!!
                • Diesel6401
                  Memento Vivere
                  • 4204
                  ive burned up the sf120 with a little bit of water. That's when I started waterproofing all of my Hifei esc's. I have done 3 of the 200s and 1 120 and all did great even with water on them. I am still running 2 of the 200s, but sold 1 and sold the 120. I am big fan of the SF200s. Size is perfect. I haven't tried the 240hv yet though, i went for a cc 240 ice instead which ended up frying from a little bit of water after i had a hardware issue that lead to water coming in the hull. Castle warranty though cant go wrong with it!
                  wow!
                  - Diesel's Youtube
                  - Diesel's Fleet
