KB8L Testing
  • SJFE
    • 4735
    KB8L Testing
    I got around to installing the KB8L in the Jolly today. I discovered the coupler probaly was the source of the wire wobble on the last KB. It's not so bad this time I was able to correct it a little buy leaving out a grub screw. I need to order a new coupler. I had to use a spare Hex due to the fact the 200 amp unit I am waiting on is STILL on back order. With the 8L's 2300kv I proped down to a S&B X637. This motor has a rep for hogging the amps and making some heat so the smaller prop on the 120 amp esc is a must. I am hoping the weather breaks this evening just before dusk. I'll take it down the lake with the gps and have at it. I set the Hex cooling up a little different this time. The water block covers the fets better when it's placed upright. lets hope the smoke stays in.
  • steveo
    • 1454
    didnt you have that combo before, maybe i am mistaken, those are some killer boats
    • SJFE
      • 4735
      I had the 8xl 1700kv. Thanks
      • Flying Scotsman
        Fast Electric Adict!
        • Jun 2007
        • 5190
        Very interested Tom, as far as heat and amps are concerned, as I have a KB45 12L that is looking for a home. The wire drive looks great
        Douggie
        • steveo
          • 1454
          what was the problem with the 8xl
          • RCprince
            • Jul 2007
            • 1637
            SJ that Speedo you have there looks like an octopus...You think It'll run cool enough
            • steveo
              • 1454
              that should do well i would go into the speedo first
              • SJFE
                • 4735
                Steveo the the Feigao cured a CG problem I had with the kb8xl. The big kb made the boat run a little wet.
                • SJFE
                  • 4735
                  HM 200AMP is in!!
                  I think I'm the first one to take delivery on one of these. As you can see from the pictures it's big. It's also got some weight to it. The wires are heavy gauge. I will get the shrink off it soon and figure out cooling.
                  • goldendesign04
                    • Jan 2008
                    • 173
                    maybe you stated this somewhere...but I failed to find. What esc is that? will it support 6s?
                    • SJFE
                      • 4735
                      I don't know anything about it yet. After I am done testing I'll know & share more. No on 6s
                      • RCprince
                        • Jul 2007
                        • 1637
                        Those are the same Esc's I use...Mines Just happens to go in boats that like to drink water. to cool mine I made a brass plate another time I drilled three holes through the cooling fin...and installed 3 aluminum tubes
                        • eboat
                          • Aug 2007
                          • 693
                          A freind has one already and it looked good
                          I have 2 in the mail headed my direction
                          • ReddyWatts
                            • 1711
                            I have one of the HV 100 amp controllers like this one. It has a double heat sink, one on each side. Had planned to air cool it, but this one needs two fans. Going to run it first and see if the two sinks will be enough cooling. Also need some bracing to steady it. Have not decided if I like this big boy.
                            ReddyWatts fleet photo
                            • RCprince
                              • Jul 2007
                              • 1637
                              HiModel GX Seires 200A 3-7S Brushless Electric Speed Controller Type GX-200A-OPTO
