What Esc should I run in a Pursuit impulse with a Leopard 4074 2000kV motor and a m445 carbon prop......
What ESC to run?
With the 2000kv version and an m445 you can run a 120a ESC.........swordy or T120.................i did it for quite a while with the 2150kv version..............but for 30 bucks more than the T120 you can go with a T180 which is what i finally did.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
M445 is beryllium copper De-tongued. X445 is beryllium copper Full blade are intact. K45, is carbon reinforced plastic with similar shape to an X445. The M445 will spin slightly "easier" Than the X445. It has slightly less blade area. The "tongue" is the very beginning of the leading edge.Comment
