I have a 7.5 bullet drive on order. I now need to chose the motor to go with it. What are the best choices for a 35"tunnel for a good combination of top speed and run times??
Outboard motor choice
Over on International waters forum there is a current discussion on 6s setups for tunnels, lots of opinions going on, Scorpion outrunners, Leopard 4082's Castle 1521's.
No experience with 6s setups so I have no valid opinion, been following this thread though.
Just a feeler thread to see what people might run with a 6s OBT. Hull is a Vision 40. MGM 250amp (3-8s) ESC Lawless 7.5 lower modified my Kris Flynn. 6s/1p lipo setup... My motors that i have for testing are. 1527/1y 1527/1.5d 1521/1y. Open for other motors other than Neu. Needs to run...
Might have something new to test next time out, this one will win in a collision! To be weird I might just clear coat it as it sits. The Rat Boat.
If my boats upside down then who owns the one I thought I was driving the last two laps? -
If you are going to be building a 6S sized Outboard, which you are... you want to look at something in the 1500KV range at best... I'd even shoot for 1300-1400, and something with MASS to it, like a Scorpion outrunner or one of the Leopards, etc... Something OTHER than a 36-ish mm diameter motor...
Just my opinion....Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Current IMPBA P-O/B Tunnel SAW record holder with avg time of 3.358 seconds @ 67.004 MPH.
Owner Worlds fastest record setting Lynx with average time of 3.287 seconds @ 68.451 MPH.
Smocktura Props!Comment
If it doesnt work out ill sell it and try something else.Current IMPBA P-O/B Tunnel SAW record holder with avg time of 3.358 seconds @ 67.004 MPH.
Or... you can just run it on 3S... It's perfect for that... 3S2P would be the same number of cells purchased as 6S1P, and, while you would be drawing more amps, you'd have longer runtime... Would need a GOOD ESC, however... most likely.
You would REALLY be better of with the RIGHT motor in the 1300-1400 KV range on 6s, or an 1800-2200 KV motor on 4S...Darin E. Jordan - Renton, WA
From this thread on International Waters:
We are looking for a low cost replacement for 7.5 nitro engines. The first test was on Leecraft XT-460 tunnels. After some trials with inexpensive motors that didn't hold up we settled on:
Scorpion HK 4025 1100 KV motor http://www.innov8tiv...products_id=569
Turnigy 180 amp speed control http://www.hobbyking...?idProduct=8937
6S 5000 40 or 45C batteries http://www.hobbyking...idProduct=14616
Hyperformance 7.5 outboard conversion kit http://hyperprod.biz...ersion_kit.html
That power plant costs around $400 with the motor at $160. Still, the cost is in line with nitro power heads. We used an old K&B lower unit. The performance of Brian's boat is better than a mod engine powered XT-460 with both electric and nitro boats running an Octura 1450 prop. You just need to run the prop a lot shallower than with a nitro engine. Bigger props torque the sponson into the water, flipping the boat. Outrunner motors worried us since they aren't as easy to water cool as inrunners, but that doesn't seem to be a problem with outboards. The next test will be an inboard setup in a Sport 40.
Lohring MillerComment
