Light weight motors?
  • Drax21
    • Jul 2011
    • 1021
    What are the lightest XL size motors you can buy?
    Everything that has a beginning, has an End
  • rearwheelin
    • 1941
    Why ?
    --Albert Einstein
    • driftah
      • 760
      xl dictates size and usually therefore weight and length etc. if it is lighter there is a chance for "skimping out" parts inside.maybe go with an l series motor,what is the application?
      • NativePaul
        Greased Weasel
        • 2760
        The lightest XL is a 380XL
        • rearwheelin
          • 1941
          I agree 380xl.
          --Albert Einstein
          • Drax21
            • Jul 2011
            • 1021
            Thanks for all you replies. I have a Apparition 32" Hull with 2 Feigaos 7XL but I don't like the weight of them. How much lighter is a Leopard or Tacon 4074? I only ask as I hear Feigaos are heavy????
              Feigao XL = 372 grams and a Leo 4074 = 374 grams. No difference. If you want to save weight you'll have to go with a smaller motor, like a Feigao L (282g) or Leo 4060 (295g). This is less of a problem in a 32" hull since the motors share the load, and a single Leo 4074 will push the Apparition hull as fast as you want anyway. Either smaller motor will work well, but you are only saving ~6 ounces total.
              • rearwheelin
                • 1941
                4074 motors are heavier than 540xls, they are bigger motors. With 2 7xl motors weight will be of no concern in a twin cat.
                --Albert Einstein
                • Drax21
                  • Jul 2011
                  • 1021
                  OK thanks for letting me know. What about Heli Motors?
                    4074 motors are heavier than 540xls, they are bigger motors..
                    Sadly incorrect and misleading to the OP. Where did you come up with that? It's not what their spec sheets say. I even put mine on a scale and guess what - they weigh the same (within the 1/4 ounce resolution of my scale anyway).
                    http://www.offshoreelectrics.com/pro...-540XL&cat=116
                    • rearwheelin
                      • 1941
                      I don't see the need to get OCD on the weight of the motors... That's sad ! I bet the water jacket wieghs more on the 4072 also ! Even if it's within a few grams..... The weight of the motors are not a issue period . Drax21 forgive me bro, I took a guess because motor weight is no concern...... Many racers add lead to there boats and for CG reasons.... FWIW go with the Leo , 4 pole motors are better, they are more efficient and put out better power to weight ratio than the 2 pole motors.
                      --Albert Einstein
                      • Drax21
                        • Jul 2011
                        • 1021
                        No worries, Yes Leopard are definitely the better motors. For now I will keep the 7 XL I have, will get a bigger rudder for steering in the water. From the car park to my lake its about 200 meters. The boat starts getting heavy after a while..... Please answer me this.... My boat tilts to the side I turn, would just a bigger rudder solve this or is there more???
                        • rearwheelin
                          • 1941
                          Boat leaning into a turn not a issue for me, helps them.
                          --Albert Einstein
                          • Jacked1
                            • Jun 2010
                            • 772
                            There are quite a few 500 heli outrunner motors that are lighter and similar in power and then you could air cool them so you would not have water jackets.
                            Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
                            • Drax21
                              • Jul 2011
                              • 1021
                              Its great on a deep V but it really slows down my cat. I have seen other Apparitions run and mine is the only one I have seen lean.
