Delta Force DF45 setup
  • DISAR
    • Aug 2007
    • 1072
    Hi guys,
    I am preparing a new boat for the summer, the delta force DF45 abt 36" long with a Feigao 9XL motor. Do you have any suggestions for ESC, batterries and popeller?
    Thanks all.
    http://www.rcfastboats.com/
  • Doby
    KANADA RULES!
    • 7280
    I run a Hydra 120 with my XL,,,and I have used my SV-27 speed controller with no problems as well, all while running on 4S LiPos.
    Grand River Marine Modellers
    • Steven Vaccaro
      • 8723
      thats a small motor for a big boat. Start with a small prop. And watch temps. A 9xl on that size boat will be a bunch of amps. I would use a 100amp continuous esc of better.
      • Doby
        KANADA RULES!
        • 7280
        Good point Steve, I'm running my set-ups in 27-28 inch hulls. A lot less current drain.
        • txboatpilot
          • Oct 2007
          • 1494
          I would use a Hydra 120/240 esc and 12XL.. Run 4S lipos and 45-50mm prop...
          I think a 36" long hull and would be very hot on 9XL..
          I run a 9XL and Hydra 120 in a 29" Titan with a M445... On a 3-4 min. run all electronics and motor are over 100 deg... It is running 40-45 mph..... I think this set-up in a 36" hull is to hot... JMO
          Nothing like keeping you lipos warm and your prop wet!!
          • DISAR
            • Aug 2007
            • 1072
            Thanks all for your suggestions. I will go for a 120 Amp ESC, 2X3S lipos and a 42-46 mm prop. Let's see!
