Can i mix capacitors when adding a bank to my ESC's stock caps?
  • Make-a-Wake
    FE Rules!
    • 5557
    I have an SF240hv and want to add the big Etti HV bank......can i use them even though they are different ratings than the six stock caps? The stock caps are 50v 470uf and the Etti caps are 63v 1000uf. Thanks!
    Etti bank - http://www.offshoreelectrics.com/pro...i-e041&cat=136
  • Boaterguy
    • 1760
    the uF ratings will be fine, I don't know about voltage but I think it is a maximum rating so as long as you don't exceed 50V it may be okay.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      He shouldnt use caps with a lesser voltage rating.
      • Make-a-Wake
        FE Rules!
        • 5557
        So adding the higher capacity 63v to the stock 50v isnt a wise thing? Thanks
        • lectriglide
          • 538
          You want to add higher voltage caps. It is done all the time with the T180's to handle larger spikes. Here's a good thread explaining it.
          http://forums.offshoreelectrics.com/...ight=capacitor
          • Lockk
            • May 2011
            • 87
            Unless I'm mis-reading something your adding the Etti cap bank to your stock cap bank and if the ratings that you posted are correct for your stock cap bank your good to go!
