Any one try one of this yet
  • lenny
    • Sep 2010
    • 4294
    Thinking of using one of these for my 36"Shockwave, With a Seaking 180a on 4s or 6s.
    http://www.hobbyking.com/hobbyking/s...00_Class_.html
    http://www.hobbyking.com/hobbyking/s...dProduct=11980
    Thanks for any input.
    ? ONLY IF THEY WORK
  • Make-a-Wake
    FE Rules!
    • 5557
    hmmmm.........seen that motor before.........
    • lenny
      • Sep 2010
      • 4294
      Find that guys number yet ?
      ? ONLY IF THEY WORK
      • Make-a-Wake
        FE Rules!
        • 5557
        lol
        • Jacked1
          • Jun 2010
          • 772
          I have the 1100kv one and it runs pretty well!
          Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
          • lenny
            • Sep 2010
            • 4294
            What did you run it in ?
            ? ONLY IF THEY WORK
            • Jacked1
              • Jun 2010
              • 772
              My surge crusher. I planned on running 8s with an hv esc but the esc I used got out of sync with it so I used it on 6s. That one is probably a little small for your shockwave tho.
                That motor is on the small side for a 36" hull with just 1200 watts recommended output. You can over-amp it but that may cause high temps and shorten its life. I'd shoot for a larger motor, more like a 600-size outrunner. But that's just me.
                • lenny
                  • Sep 2010
                  • 4294
                  Thank for input Jay,
                  I was trying to run the boat on 4s,
                  Because i have those cells, But i may have to make the jump to 6s
                  How about one of these on 4s ? http://www.hobbyking.com/hobbyking/s...dProduct=11980
                  ? ONLY IF THEY WORK
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    That 600 motor would be very sufficient. You would have to run a larger prop to get decent speed on 4s........maybe in the 45-48mm range. Not sure what your speed goal is, but the 500 motor should work with a smaller prop and speed goals in the lower 30's. The variable here is what speeds you want............
                    • lenny
                      • Sep 2010
                      • 4294
                      Thinking low 40 should be fun,with good run time and cool setup.
                      ? ONLY IF THEY WORK
                      • sailr
                        • Nov 2007
                        • 6927
                        For 4S you need to be in the 1800-2200KV range. However, that being said, Outrunner motors deliver a LOT more torque than the inrunners we typically use. Therefore, you should be able to swing a bigger prop.
                        Whichever you choose, keep us posted! I'm always wanting to learn more about the application of Outrunners in boats. How do you plan to water cool it?
                        Mini Cat Racing USA
                        www.minicatracingusa.com
                        • lenny
                          • Sep 2010
                          • 4294
                          Old school copper tubing wrap and water cooled motor mount,
                          Still trying to think out of the box.
                          ? ONLY IF THEY WORK
                          • lenny
                            • Sep 2010
                            • 4294
                            With the T600 1400kv motor 0n 4s or 6s will the seaking 180a handle it ok ?
                            ? ONLY IF THEY WORK
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              Yes.
