Need some Clarification on these Motor Specs
  • RCprince
    • Jul 2007
    • 1637
    Can some explain to me contrary to popular belief why ammo motors of the same size can produce more power(wattage) than a 6 pole lower kv motor...My LHS told me also that Ammo over exaggerate their specs. case and point they have a 28-56-3200 motor putting out 666 watts...thats 90% of 1 horse power
    Most likely Proboat Brushless BJ Stock Motor:
    HiMaxx HB 3630-1500
    Dia mm: 36
    Length mm: 53
    Kv (RPM/volt):1606
    Efficiency % 87
    Max Amps: 55
    Wattage:600
    Poles: 6
    Max RPM: 40,000
    Ammo In-Runner Brushless Motor
    36-50-2300
    Dia mm: 36
    Length mm: 50
    Kv (RPM/volt): 2300
    Efficiency % up to 89
    Max Amps: 100
    Wattage: 1110
    Surge Wattage: 1850
    Poles: 2
    36-50-3300
    Dia mm: 36
    Length mm: 50
    Kv (RPM/volt): 3300
    Max Amps: 100
    Wattage: 832
    Surge Wattage: 1850
    Poles: 2
  • Steven Vaccaro
    • 8721
    Specs are just specs unless the same person runs them and posts the info.
    Thats why all us racers test on our own. The fastest guys usually test the most and tune the best.
    Steven Vaccaro
    • RCprince
      • Jul 2007
      • 1637
      Thanks Steve the reason I asked is because I'm a mad scientist...I hooked up 7s to an Ammo 36X50 3300kv mtr running a 637 prop....the boat ran fast mtr just warm to the touch
      • Steven Vaccaro
        • 8721
        thats 70k rpm.... What am I missing? If that was the case you would be in the 130mph range.
        Steven Vaccaro
        • RCprince
          • Jul 2007
          • 1637
          Thats why I guess specs like you said are just Specs....probably at that high voltage which is 2s above spec max voltage efficiency goes down dramatically.....at 34 bucks i wanted to see if the mtr would blow up...but it held up....
          • RCprince
            • Jul 2007
            • 1637
            I may have been in the high 50's early 60's before I ran out of lake space....I was also on the verge of going airborne. before I test these mtr I use your conversion chart to calculate speed, and I get the same thing...but as I lower the mtr efficiency the speed becomes more realistic
            • Steven Vaccaro
              • 8721
              But as you decrease efficiency you increase amps and heat.
              KV RPM specs from most companies should be real close. The specs in question are efficiency, watts and max amps. They can make the numbers look how ever they like.
              I have to warn people reading this thread. I would in no way recommend running this setup. It WILL end up blowing something up.
              You want to be a mad scientist? Buy or borrow a eagle tree with the brushless sensor and post the results with a video of the run. Than we can get an idea of whats going on in there.
              Steven Vaccaro
              • SJFE
                • 4735
                I'd pay good money to see THAT video.
                • RCprince
                  • Jul 2007
                  • 1637
                  I over did it when I ran that same set up with a x645, It melted the solder on one of mine connectors and killed my 110 Hv...But with the 637 I ran it on 2 full recharges of the lipo....remember these are runs that are about 300 to 400 + feet oneway, then we run the otherway....But in noway or fashion m I trying to deceive anyone...just reporting what I experience...our 1,000 dollar sony Camera won't keep it's recording on disc...it keeps corrupting the disc and keeps trying to repair the data to no avail.
                  • domwilson
                    Moderator
                    • 4408
                    These are decent. I have a couple of them.
                    Government Moto:
                    • Steven Vaccaro
                      • 8721
                      I understand your not trying to deceive anyone. Just letting the young-ins understand this isn't the setup to run.
                      Steven Vaccaro
                      • SJFE
                        • 4735
                        I wana be clear also...all I wana see it your boat blow off the water ...Nuffin but love for ya man
                        • Flying Scotsman
                          Fast Electric Adict!
                          • Jun 2007
                          • 5190
                          A very sensible positition. Way too hot a set up and people with less experience will follow that set up, because they want speed without knowing the consequences that a high rpm small motor coupled with high voltage and large props will result in.
                          Douggie
                          • blakybob
                            • 126
                            I'd like to chime in on the Eagle Tree suggestion. I'd love to see some rpm and amp charts. That's definitely a "mad scientist" setup IMO.
                            Blake
                            • domwilson
                              Moderator
                              • 4408
                              Somebody was doing some deep digging...2 1/2 years later....
                              Government Moto:
