rigger queston
  • iceman
    • Aug 2011
    • 72
    rigger queston
    when mounting sponsons to tub how much do you want the sponson below the tub? thanks for putting up with my questions.
    GARY
  • Boaterguy
    • 1760
    it just has to be enough to lift the tub out of the water when on plane, an inch or so is most likely enough.
    • iceman
      • Aug 2011
      • 72
      thanks for the quick reply. does the pads on the back have to be the same hight as the bottom of the sponsons to make tub level on plane?
      • m4a1usr
        Fast Electric Addict
        • 2038
        View from the bottom;
        John
        Change is the one Constant
        • Boaterguy
          • 1760
          I dunno about that, not all riggers have pads, mine doesn't. but if you want it to be level on plane it's most likely a good idea.
          • siberianhusky
            • Dec 2009
            • 2187
            What's the strut depth? depends on the entire design, you want the tub to ride level. Use your experience with other riggers and check out other peoples boats and any plans you have and do something similar. Even then depending on the setup it may be wrong, the joys of designing a boat, could put tons of effort into something that doesn't work! All the good ones have been refined over time and testing, build it run it and start designing a new one to fix the problems, repeat until you're happy!Took 3 very experienced guys quite a while to get the JAE to where they were ready to call it finished.Always exciting to hear about a new design nearing completion.
