Picked up a pursuit recently, and I really like it. It has a fsd 3660 1620kv motor, and the yellow shrink wrapped esc that appears to be sealed with some sort of white epoxy/glue. Runs decent on the stock prop, on 5s lipo. A bit slow on 4s. Not sure that the stock brass prop is, but it appears to be about 40mm in diameter, and looks to be less than 1.4 pitch. It does not have as much blade area as an octura x440, and no tounge to speak of either.
Pretty sure this prop on 5s is about the max the 3660 can handle, as it is getting warmer than I like. Not blazing hot, but certainly not cool. Stock esc seems to be fine, but it is not very progressive, and I doubt it has any programming?
Anyways, I have a neu 1521 1y in the motor drawer, as well as a hydra 180 hv that no one seems to want to buy. I would like speeds of around 45 - 50mph, and would like the boat to run my 4000mah 5s 40c lipos.
I have a x440 prop to start with, any suggestions of what prop size will give me the desired speed with my motor battery combo? This is a larger boat than I am used to, so should I go up in prop diameter and stay with 1.4 pitch props, or go to a 1.6 pitch prop and smaller diameter?
Wondering if I should reinforce the hull of this boat? The neu is heavy, and much more torquey than the fsd. I run in very calm water, a wide canal in my backyard. All I do is sport run, no racing.
I will say one thing, this boat is 10 times more stable than my supervee (super flip?)...
Thanks for all of the help guys.
