df33 rail's
  • CHUD
    • 497
    df33 rail's
    Hay bud's got my new df 33 and I'm so happy fast shipping thank's to steven at ose,But I didn't get the rail's . I was going to cut some basa myself,But then came up with something new at least I haven't seen it yet,Can anyone tell me who can cut me some alluminum rail's,for my motor to mount to about 1''1/4 high and 15'' long with the bottum of each on a 60 degree 's angle,who do I need to talk to.
  • HYDROJERRY
    • Jan 2010
    • 2503
    Hay bro that guy who did my servo mount is here,,,ask him, http://forums.offshoreelectrics.com/...or-mount/page4
    • Rumdog
      • 6453
      Aluminum rails are gonna be really heavy! What is your setup going to be?
      • CHUD
        • 497
        rumdog ,I'm puttin my ul1 and aT120 and38mm 40mm45mm 47mm 2 blad prop's to test with 1.50/316 AND2 /2s 40or30/5000ma ,My brother hj thinks it might be to heavy two,
          Whatever you do don't use balsa for motor rails, that will be way too weak and will fail in a hard crash. As far as aluminum rails, a few extra ounces of weight will do nothing to the performance of the boat, while it will give higher reliability in the event of a crash. If you're scared of aluminum, then use 3/16" plywood from the LHS.
          • HYDROJERRY
            • Jan 2010
            • 2503
            aluminum that size weighs almost nothing in your hand would it be that big of a difference,,
            • cacofonix
              • Jul 2008
              • 240
              hi there
              weight will depend on thickness and all cut that can be done
              but using a 0,078 sheet ....weight will be almost nothing.
              my main problem is that my CNC can not go over 8 / 9" length
              herve
              • Chilli
                • Jan 2008
                • 3070
                I try to keep conductive materials to a minimum in my electric boats.
                WOOD is GOOD. Do what Fluid says.
                Mike Chirillo
                www.capitolrcmodelboats.com
                • CHUD
                  • 497
                  hay bud can it be 1/4 of a inch thick ,take a look at this pic
                  • CHUD
                    • 497
                    Thanks for the info ,But what if I coat them with a a thin coat of apoxy to be safe,
                    • carlcisneros
                      • Jan 2010
                      • 1218
                      please listen to Nautiboyz.
                      Keep conductive material to a MINMUM inside the hull.
                      and 3/16" ply is fine for the stringers.
                      1/4 and up adds more weight.
                      just take you time and do a nice neat job of installing them. (don't over do it with epoxy as it only adds weight.)
                      I have a used 33DF that I will be installing stringers in and the thickest I will use is 3/16" ply.
                      And you don't have to stay at 1 1/4" tall all the way on them as well. you can start out at maybe 1/2 inch, then go to what ever heighth you need
                      for your mount, then decrease it back to 1/2 at the transom.
                      • Chilli
                        • Jan 2008
                        • 3070
                        What ever material you use. After you epoxy the stringers in, get some 1" or 1 1/2" fiberglass cloth tape and glass those stringers in. They will never come off in a flip or stuff. I only glass the inboard side of the rails and then lay a bead of expoxy down the outboard sides where the rail meets the hull.
                        Mike Chirillo
                        • CHUD
                          • 497
                          Thanks guy's from VA ,I 'm goin to go with carbon fibber,sorry for being a hard head,
                          • carlcisneros
                            • Jan 2010
                            • 1218
                            LOL no problem Chud.
                            that is what we are here for.
                            • cacofonix
                              • Jul 2008
                              • 240
                              hello
                              in all my hull, every thing is made in aluminium
                              motor mount, water jacket, servo mount, even lipo mount .......
                              what is the problem ????
                              i never had a problem
                              herve
