Thanks Steven................ Others were asking you about top end on the thread, i got 46 mph as a high reading with the same setup and an x442..............just fyi
32 pursuit
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight= -
pursuit
and i got my prop from here.Comment
Hey savy what do you mean in parellel ,is this 1 or 2 packs. I and went to the site u send me great prices .w hat mah are u using. How much does the prop cost.http://www.hobbypartz.com/skylipo5s40c.html
parellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
series means, one positive and one negitive from each battery made into one battery lead and again the other postive and negitive made into another. this gives you the same capacity as one battery, but doubles your voltage.
++ & -- = parellel
+- & +- = series
does this make sence?
i use 40 c lipo's so in parellel in makes 80c.
this is the prop i use : http://www.offshoreelectrics.com/pro...?prod=oct-x642
but if you want a sharpend and balanced prop: http://www.offshoreelectrics.com/pro...rod=octsb-x642
i also have the one pcs driveshaft, much easier to service.Comment
Hey savy thank you for all your help did u get the pursuit from ose or kintech the motors are diffrent.parellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
++ & -- = parellel
+- & +- = series
Still 40c no matter how many you hook together.............parellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
++ & -- = parellel
+- & +- = series
40c x 5000mah = 200 cont. amps
40c x (2 x 5000) = 400 cont. amps
Good explaination of the series/parallel though..............
http://forums.offshoreelectrics.com/...est!&highlight=Comment
i've ordered a couple of small things from here, and in my years of lurking in this and other forums, i have never heard anybody, ever, say they had buyer's remorse dealing with osc. to the contrary, everybody seems happy. i have never read anything negative at all from anyone.Comment
