Grease Issues on Apparition
  • penz
    • Jun 2011
    • 139
    I am having issues with keeping the grease in the stuffing tube... As the flex shaft turns it forces the grease down the stuffing w/liner, and it comes out where the stuffing tube enters the strut. On the bench even after a few blips of the throttle grease is coming out and the stuffing tube starts to warm up... is that normal? Seems like the flex shaft is too good of a fit in the liner and it acts more like a pump...pumping all the grease out... Can I ditch the liner? Will that create any problems? Also where the stuffing tube enters the strut is where the grease is leaking out, is it ok to seal this area to keep the grease in? The stuffing tube is fully engaged in the strut, its just not a tight fit.
    Ultimately I keep getting water in through the stuffing tube when all the grease is gone, and that's not even 1 full run cycle... Annoying!!
    Help!...
    LST XXL-4074 Taco, Slash 4x4-3660 Taco, Appparition-3674 Taco
  • penz
    • Jun 2011
    • 139
    Ok well I took the liner in the stuffing tube out, it pulled right out nice and easy so that was good. Greased up the flex shaft and put it back in the stuffing tube without the liner. I also used some silicone to seal where the stuffing tube enters the strut. Bench testing everyting seems to be better. No grease coming out where stuffing tube meets strut, and the stuffing tube gets a little warm but not hot like it was getting.
    I think this should solve my issues with water coming up through the stuffing tube.
    I hope to get the boat on the water today or tomorrow so I will report back my findings.
