In the build section you can see I'm doing a proboat shockwave 26. The stinger strut I am using is from a SV27R.
So questions are....
1) Does cutting it shorter affect things in a positive/negative way?
2) Is it ok for the rudder to be in front of the prop (to the side obviously), or should I make a longer bracket so the leading/trailing edge of the prop is aligned with the prop?
3) If I should make it longer, what is the proper alignment? Leading vs trailing edge of the rudder to leading vs trailing side of the prop?
