a little help with my hydromite please
  • Avanti
    • Nov 2007
    • 1280
    I would like some input on some cheap ebay stuff for the hydromite
    what do you guys think
    Item number: 260207479263 http://cgi.ebay.com/2x-15C-11-1v-150...QQcmdZViewItem
    3-Cell 15C 11.1v 1500mAh Li-Po Battery
    Item number: 260207155111 http://cgi.ebay.com/1700-Outrunner-B...QQcmdZViewItem
    1700 Outrunner Brushless Motor + 30A ESC
    this stuff is really cheap and it is the only way I can afford to get the boat running right now. is it worth a go or should I wait??
  • Diegoboy
    • Mar 2007
    • 7244
    Links are broken...
    Item number: 260207479263 3-Cell 15C 11.1v 1500mAh Li-Po Battery
    Item number: 260207155111 1700 Outrunner Brushless Motor + 30A ESC
    Are you sure you want an outrunner?
    • Avanti
      • Nov 2007
      • 1280
      not sure at all about the outrunner that's why I'm asking. I'm still new to brushless and lipo this stuff was not around when I was younger.
      • hebner
        • 647
        Here is a link to check out for info on inexpensive motor & esc like you are looking at.
        Our pond at Santee Lakes is FE friendly; but, as some of you know from "the Red Board", I complain a lot about the size of the pond. With a three-ton rock sticking out of the easterly third and four bridge piers running through the middle, it does not leave a whole lot of room for bigger...
        Hugh
        • SJFE
          • 4735
          I'd wait on it. I've cursed myself more than once doin this.
          • lonewolf
            • Jul 2007
            • 658
            1st do your research for what ya need then research the parts. Sme guys are running outrunners but i am the last to say anything about set ups
            personally i like the swapshops It is a bit more personal, If used you can get a history of the item ebay not so much. Now new items if it is from a reputable vender go for it..... Not so much for info about the items but more about shopping for them. Dave
            Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
            • Avanti
              • Nov 2007
              • 1280
              Hugh
              Thanks Hugh great link, I think I'll go for it. not a lot to lose here like some of the bigger stuff. Hell it's cheaper than the crappy tenergy batteries I bought
              • Avanti
                • Nov 2007
                • 1280
                well this is what I went with (I will worry about a 2s lipo later) I liked what I saw for that Santee spec hydro seems like a great starter class for guy/gals on a tight budget. I'll let you know how it works out when I get my goodies and install them.
                item# 130194159262 11.1v 1500mah 15C Li-Polymer Battery,burst 20C
                Continuous Discharge Rate: 15C
                Burst Rate: 20C
                Voltage: 11.1v.
                Mah: 1500
                Size: 67mm X 40mm X 20mm
                Weight: 94g
                item# 260207155089 3000 Outrunner Brushless Motor + 30A ESC
                Motor Specifications:
                Rpm(Kv): 3000Rpm/V
                Max Currect: 25A
                Recommended Input Voltage: 6 - 18 Volt
                Max Eff: 96%
                Weight: 51g (Motor only)
                Total Length: 45.6mm (Motor and Shaft)
                Motor Body Diameter: 25.9mm
                Shaft Diameter: 2.26mm(Front)
                Shaft Length: 13.3mm
                ESC Specifications:
                Constant Current: 30A
                Input Volt: 6V - 12V
                Max Current: 40A
                Low-Voltage Cutoff: Auto detect and set
                Size: 51.6mm x 23.9mm x 8.5mm
                Weight: 26g( Net Weight )
                • FE_Chris
                  • Jun 2007
                  • 764
                  Hey Avanti, for future referance, UH.com has some cheap, nicer I guess lipo batteries. They sell them under that zippy lipo name. Seems like they had the smaller ones like this with 20-25-30c continuous discharge rates. Might be a little nicer than some ebay packs, but who knows. just thaught you may like to check them out. seeya.
                  • Avanti
                    • Nov 2007
                    • 1280
                    the motor and esc was under 30 bucks
                    and the battery was like 15
                    should hold me over till I can get some extra cash flow going.
                    • Avanti
                      • Nov 2007
                      • 1280
                      Thanks everyone
