Help finding motors similar to t600 880kv -maybe Himodel Pro series outrunners?
  • FastVee
    • Aug 2008
    • 649
    Any 1 tried 1?
    I need something like 880kv t600´s ,but hc is out of stock.
    These look good but I have no idea of comparing these ...
    HiModel PRO Series 910KV Outrunner Brushless Motor for 600-700 Helicopter Type HG3740PRO-4T from manufacturer HiModel, in category Electric Brushless Motors - Outrunner, (Brushless) Motors & Accessories.
    http://www.hobbyking.com/hobbyking/s...dProduct=11143
    These are smaller dia then turnigy but longer.
    Also no idea if these himodels use 25 or 30mm bolt pattern.
    Would like to get my boat wet soon, but cant afford neus or leos atm.
    www.youtube.com/rangerpate
  • siberianhusky
    • Dec 2009
    • 2187
    the T-600's are Suppo outrunners I think re badged as HK or Turnigy. A search for suppo may find you a retailer of that same motor different label.
    • FastVee
      • Aug 2008
      • 649
      Thanks, could not find anything that looks like t600´s ,but on http://www.suppomodel.com/ ,they have same motors that I linked on himodel.
      Really tempted to try these longer motors... -maybe even lower kv to get the smoking in control inside the boat...
      • siberianhusky
        • Dec 2009
        • 2187
        Sorry my mistake that turnigy is not a suppo
        http://www.hobbyking.com/hobbyking/s...r%5F910kv.html
        is a suppo, same as the hi model one you linked to, I have the silver and black 3637 2t.
        • FastVee
          • Aug 2008
          • 649
          Thanks!
          Still I have no idea what these are like compared to t600´s...
          a bit smaller dia, but longer and 3000watts is not that bad (if that is true wattage).
          ideas?
          Pate
          • carlcisneros
            • Jan 2010
            • 1218
            the Suppo 3740 and 3736 motors are a very good motor.
            Make sure that you lock tight the set screw up in the end bell assembly as they sometimes do not use it.
            As for the T-600's, I have no idea who actually makes those (and those are also very good motors.) (there price from HK is now 60 bucks and I paid 39 for mine last winter).
            Fightercat57 on the forum here carries the suppo line of outrunners in a good KV range. (thats where I get mine).
            • FastVee
              • Aug 2008
              • 649
              Thanks, I ordered the 3740 910kv motors. Will reply when I have tested them.
              I allways check the set screws, but thanks for the information.
              I have 2 of the t600´s and paid 32$ . the price drops when you log in to hc.(I am platinum member so that could drop the price some also?)
              Pate
