New to FE, Building a hydro need ESC Motor Bat help
  • Alexgar
    • Aug 2009
    • 3534
    Btw paid 115 and 105 for the castles with wj
    • Make-a-Wake
      FE Rules!
      • 5557
      My P-Sport Hydro rig uses 2 x 4S 4000's. They just fit and the extra weight helps stability in racewater.
      My second thought was for lower mah 4s batts...................yours at 4000 are quite a bit lighter than the 5500's he wanted to run, he should consider some 3500-4000 4s batts for parallel also.
      • hydro rob
        • Jun 2011
        • 9
        Thanks guys, Propper Chop, I met you at legg lake back in march when you got dunked for winning the P class, I was with the guys from Vegas. So you think the 4000 Mah bats in 4S would be better for weight? That hull is a Miss Attitude, made by Dominator, who is no longer making them. Only about 100 were made I had 3 at one time but decided to keep this one for some reason and found my reason now as an FE boat.
        • properchopper
          • 6968
          The 5500's might just be too much weight on 4S2P but who knows ? One should be sufficient for @ 3 min runtime. There is a ose member named Gary who about a year or so ago had his Dominator Miss Attitude do 100 mph !! Old thread; search "Gary". BTW if you set the boat up for Spec (UL-1) motor you can come here July 16/17 for some FE Sprint racing.
          • hydro rob
            • Jun 2011
            • 9
            you guys dont race p sport? only p spec? I would have to get some ul1 stuff. what is the needed electronics for p spec would love to race with you guys, is there a hull dimension limit or something? I sold one to gary i think and spoke to him a few times on another forum was happy to see him hit 100 with it!
            • hydro rob
              • Jun 2011
              • 9
              I plan on comming out in july...will know more tommrow when I talk to Jim.
              • properchopper
                • 6968
                Rob, We raced P-Sport at the race you were at. I won the class with my Spec boat; the P-Sports were going faster than they could survive following the gasser heats with the water really chopped up. All you have to do to your P-Sport boat is drop in a UL-1 motor - that's what I did last weekend at the Nat's at Legg. Length limit is
                34" BTW.
