I converted my 46" Purple Light hydro from a RCMK Evo gasser to electric power with RED LEOPARD BM-5682-1090kV MOTOR. IS THE MOTOR THE PROBLEM OR TOO BIG OF PROPS???
STEUPS
1. Seaking 80A-HV speed controller (good for up to 12S Lipos)
Two DRAGON RED 4800mAh 45C batteries in series (29.6V)
Octura 61mm+- three blade prop (#?)
RESULTS: fried one Lipo cell. Tried a second battery - same result. Both dead. Tested speed contl. At home - smoked it & burned thru shrink wrap at lead "A"
2.. Seaking 180A-HV speed controller (good for up to 6S Lipos)
One DRAGON RED 4800mAh 45C battery
Used the Chinese 68.6mm two blade prop came with boat cut down to 54.4mm.
RESULTS: First run OK for a minute then silver soldered Deans plug melted off.
Second run with new battery & plug. wires melted thru foam, Deans plugs & in three places.
Gonna try this setup next:
SeaMonster BL3650 2300KV motor (34K RPM @ 14.8V)
Octura X447-3 prop
Any help or suggestions to get my hydro up to gas powered speeds are welcome. THX-JIM
STEUPS
Octura X447-3 prop
