Unscrewing Collet?!
  • nosreme722
    • May 2011
    • 181
    Originally posted by lectriglide
    I've tried this method and have found it to rarely work for me (usually bends or breaks off exterior of slit). Much better is to use a torx tip. Apply heat first, then lightly tap the tip in. It will bite and come right out.
    I may try that.. but if it doesnt work immediately im just goin to buy another. Im going to need another for a project anyway so that'll do. I have very little patient right now, ive got a brand new tacon 4074 2000kv and seaking 180a waiting in my MG and i havent ran it yet.
    • U1Racing
      • 62
      grinding a slot then using a Flathead is the easiest way that i have found to remove stripped out set screws
      too much power not in the FE racing dictionary
      • makin' waves
        • Jun 2011
        • 92
        Think the glue idea is the best, trying to cut a slit in the tiny grub screw will be a nightmare...
        Thanks for the tip Detox!
        Tone
        • lenny
          • Sep 2010
          • 4294
          Some time freon gas work to brake things loose like heat does.
          ? ONLY IF THEY WORK
          • Stinger9D9
            • Jun 2007
            • 355
            One other option is to try a good, new, 1/16" allen wrench. It's just a smidge bigger than 1.5mm and may work. I had a stripped setscrew in an AQ coupler yesterday and a 1/16" wrecnh worked for me.
            The 1.5mm wrench is 0.059" while a 1/16" is 0.062" (well it should be if it's a quality wrench). That extra 0.003" might make enough difference to get the screw out.
