6mm & 8mm thrust bearings
  • Steven Vaccaro
    • 8721
    I have finally found a source for quality 6mm & 8mm thrust bearings. They will all have metal carrier's with grooved bearings. They will be $8.95. And should be in mid next week.
    Steven Vaccaro
  • Darin Jordan
    • 8335
    Hmmm... and I just recieved an order from you yesterday (thanks for the shrink, by the way! )...
    I'll check the site next week... timing will be good... I need to start on my P-Mono shortly...
    Darin E. Jordan - Renton, WA
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      Steven, what are the stated RPM and load factors for these bearings?
      • Jeff Wohlt
        • Jan 2008
        • 2716
        Hey Darin... What motor would you run in a P Sport with a 6 or 8mm Shaft?
        www.rcraceboat.com
        [email protected]
        • Darin Jordan
          • 8335
          Special order 1521... Has had the endbell screwed/pinned as well...
          If length limits don't get voted in, however, I'll be ordering a 1527 with the same shaft size... and getting a larger hull...
          • Jeff Wohlt
            • Jan 2008
            • 2716
            Thanks for the info. Bigger motors and bigger hulls for P....it is amazing how we tried to keep hulls on the minimum side and now with the power we are going to larger hulls.....that is cool.
            IT just gets better and better!
            www.rcraceboat.com
            [email protected]
            • Darin Jordan
              • 8335
              ...and now with the power we are going to larger hulls.....that is cool.
              Actually Jeff... I'm REALLY hoping that the membership of NAMBA sees the light and realizes that we need to get these hull sizes in check... It's only going to be "cool" for a small part of the membership that can afford to put together a 39" P-Mono setup if we don't get some length restrictions in place like IMPBA is trying to do... I'd really rather see a system where more people can participate on a competitive level...
              In other words... I REALLY don't WANT to build a HUGE P-Mono... I'd rather build something that's under 34"...
              • Jeff Wohlt
                • Jan 2008
                • 2716
                I agree with you, Darin. We will all be running by ourselves if we can't attract the others that can play a little cheaper yet keep excited about the hobby.
                www.rcraceboat.com
                [email protected]
