Ok. I have water coming from behind one of the drives bolted to the rear of my MHZ Mystic. It is screwed on from the inside of the hull. What are the screws screwed into. Nuts or a plate? And how do i seal it up?
Chris.
Yes it is Andrew but, I need to find out if the bolts thru the hull go into nuts or into a plate inside the mock gearbox on the outside of the hull.
Then i can remove it and seal it up.
I got the boat as a rtr so im not sure if what i want to do is correct.
Thanks,
Chris.
The 3 bolts go thru the hull and into the "gearbox" part of the drive.
See attached pictures. Not the best pictures but it will give you an idea.
Anbjørn
