Which Combo?
  • G1ST
    • Dec 2010
    • 348
    Which Combo?
    I am finishing up a rebuild of an Ovalmaster 29 and I have 2 power combos I can put in it.
    First is a KB 9L (2700kv), Seaking 90, 3S 4400mah battery and a carbon 42mm prop.
    Second is a Castle 1512 (1800kv), Seaking 90, 4S 5000mah battery and the same carbon 42mm prop.
    What do all of the experts think? I don't want to create a grenade.
    Is either combo safe or should I set it aside until I can change out some components?
    Any recommendatiuons are welcome
    Thanks
    Greg
  • m4a1usr
    Fast Electric Addict
    • 2038
    That would be my vote. Might want to bump up to a 120 esc if you want long run times. If setup pretty loose the 90 can work.
    John
    Change is the one Constant
    • Boaterguy
      • 1760
      You might want to prop up a little on the 2nd setup (1800kv 4S), but if you do, it would be a good idea to get a t120 or any other 120 esc.
        • 9488
        The CC1512 running a M445 would rip
        • Alexgar
          • Aug 2009
          • 3534
          i have an cc1800 on a sf120 4s m545 and she moves
          • G1ST
            • Dec 2010
            • 348
            Thanks Guys.
            I'll go with the 1512 on 4S.
            Lots of expenses these days so I'm stuck with the Seaking 90 and the carbon prop for a couple of months. I just dont want to blow anything up.
            I appreciate the help
            Greg
