Deans, XT60, Andersons, anyone use these? Or bullets the only way to go?
  • kola
    • May 2011
    • 47
    Just curious if anyone has good luck using any other connectors other than bullets for their boats. Im not a huge fan of bullets but are deans,xt60's, EC5's and andersons just not able to handle the amps that are required for FE boats that bullets are the only choice?
  • kola
    • May 2011
    • 47
    Never mind I see bullets are the only way to go for these set ups
    • JimClark
      • 5907
      For what setup?
      Billy Graham
      • kola
        • May 2011
        • 47
        Well initially ill be hooking up two Gens ace 4000mah 4S1P 14.8V 25C Lipo batteries on parallel, in a kintec pursuit with a Leopard 4074 2000kv motor and Seaking 180amp esc.
        Would EC5's work? I see they have a 120 amp rating but isnt that the same a 5.5mm bullets?
        • turbobuick6
          • 42
          an EC5 connector is just a 5.5mm bullet connector in a case. makes it so much easier NOT to plug things in the wrong way.
          • JimClark
            • 5907
            I have some EC-5's but have not used them yet but my setup probably only pulls 60 to 70 amps and I am sure they will be fine. Sounds like yours will pull higher amps I think the 5.5 bullits would be better
            Billy Graham
            • JimClark
              • 5907
              The male side is actually made like the smaller 3.5mm bullets the good 5.5 bullits are for sure more heavy duty and may fit together tighter
              Billy Graham
              • Alexgar
                • Aug 2009
                • 3534
                I use ec5s in a 120-140 amp set up and works fine
