Eagle Tree Question...
  • Gunny
    Zombie Hunter
    • Feb 2011
    • 71
    Why is it that when I save the data file to my computer, than close the Eagle Tree program, re-open Eagle Tree, than load the file, and I get all the data except for the GPS speed. Why is that? Any help would be appreciated.
    Oh ya on a positive note, I did hit 58mph with the UL-1
    A bizarre incident in the outskirts of an American suburb. It was later revealed the disaster was caused by the T-Virus. A mutagentic toxin created by Umbrella Incorporated for use in bio-weapon experiments. Don't worry the zombies are looking for brains, you're safe.
  • longballlumber
    • 3132
    Gunny,
    I have the same issue with some of my files too.... I will be curious to see if anyone has an answer.
    Mike
    • Gunny
      Zombie Hunter
      • Feb 2011
      • 71
      I've posted this issue in several forums, and no one has any info. I've sent the issue to Eagle Tree themselves, so we will see what happens.
      • GeoVW72
        • Jun 2010
        • 258
        Had the same issue.
        Download and re-install the software, you eventually get the prompt to fix/patch the installed program.
        Let it do it's thing and I haven't had the issue since.
        Team Boca Bearings
        S&G Design
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 989
          Yep. Check for software and device firmware updates. That could very well be the problem.
          You may not be able to retrieve the data for previously saved files though after doing the update. When I save my data files I usually use the "Save Sessions As" option rather than using the "Save Recorder File" option. Let us know what you find out.
          Sean
          • Gunny
            Zombie Hunter
            • Feb 2011
            • 71
            nope, nada, zilch! still doing same thing. oh well
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 989
              Try setting up a new model using the setup wizard. Make sure to have all of the sensors plugged in when doing the setup. It should work fine for future recorder files, but your old files will still be "corrupt".
              • Gunny
                Zombie Hunter
                • Feb 2011
                • 71
                nope. didn't work. I didn't notice before, but do now, but the temp readings show up as 0 now also. gives max and min for temp as 0 and max for gps 59293300.00 and min as 59118683.00. go figure....
                when I download from the e-logger, everything is there in perfect order. Temps, gps speed, etc. but when I go to save session and save it, than close out program and re-open, I get that crud I. Oh well, I guess it just means i cant save files.
