charging GPs @ 7 amps
  • ozboater
    • May 2007
    • 415
    seems my mrc 977 has taken a dump again... i m thinking about replacing it with the triton 2... i ve been charging my stock of gp 3300s at 1 / 3.3 and 5 amps... i see the triton can charger @ 7 amps... is this too much for the packs ??
    cheers
  • JimClark
    • 5907
    They didn't vent at that charge rate? they might be ok but I wouldn't reccomend those kind of charge rates.4 to 5 amps max especially if you are a sport runner.
    Jim
    Billy Graham
    • ozboater
      • May 2007
      • 415
      thanks for the reply jim... i haven t charged them at 5 amps yet... infact i don t even have the charger... just curious if they (the GPs) could handle the rate...
        • 8011
        The GPs will not be able to handle a full charge cycle at 7 amps. They will get way too hot by the time they are done. Perhaps some software does start at 7 amps and drops that rate over time, that would reduce the charge time.
        • ozboater
          • May 2007
          • 415
          cool... thanks for the info... what charge rate would you recommend for the GPs ??
          • kck741
            • Aug 2007
            • 265
            I charge mine at 1or2 amps
            S.S.R.C-Southern Style Radio Control
            • JimClark
              • 5907
              What really matters on these high amp charges is what delta peak the charger is set at. I have not done it myself but I know plenty of people who charged them at 6 amps with no problems. 1 to 2 amps is too low even for sport running. 4 amps does a very good job and gets the cells slightly warm which is what you want when putting them in the boat.
              Jim
              Billy Graham
              • ozboater
                • May 2007
                • 415
                i alternate between 1 / 3.3 and 5 amps... usually more in the 5 amps range... hell, who doesn t love the extra speed ?? :)... typically i set the delta peak at 35..
                • SweetAccord
                  Speed Passion
                  • Oct 2007
                  • 1302
                  The higher rate you charge the batteries at the shorter life they will have. You will gain quicker charge rate times but at the cost of the packs life expectancy.
                  4 amp charge rate is ideal, so after they are charged they are lightly warm it ideal.
