two unrelated questions
  • Boaterguy
    • 1760
    1. I was out running my roundnose the other day (it died and refuses to work now, I think its the esc) and since I was just testing a new setup, it was the first time I got it up to a reasonable speed. Once I get there, the whole boat bounces about 3 inches out of the water, in a fast motion, this really causes drag when the boat lands and digs into the water again, I tried adjusting the balance both fore and aft, It didnt change much, Is the boat too light? too heavy?
    2. I was rebuilding my tug, and in an attempt to pull a bolt off the threads on the shaft, I (without thinking) grabbed the threads with a pair of pliers, they are now ruined, I don't have a laithe so I cant really rework them, are there any solutions?
  • JimClark
    • 5907
    Is this motion a side to side like it is walking on the sponsons? Got any video of ot doing this?
    Billy Graham
    • dag-nabit
      • Feb 2011
      • 775
      You could chase the threads with a die, if you can find the correct size and thread pitch.
      Kevin
      • Boaterguy
        • 1760
        I will get video once I figure out the other problems, it is not side to side but just bouncing up and down on the water.
        • sailr
          • Nov 2007
          • 6927
          Is it bouncing nose high or straight up and down? If nose high, you need to adjust the strut with some more negative angle to keep the nose down.
          Mini Cat Racing USA
          www.minicatracingusa.com
          • JimClark
            • 5907
            More info about the setup and boat is needed how big what motor and prop and what batteries
            Billy Graham
            • Boaterguy
              • 1760
              Its a subsurface staright shaft, 3600kv on 3S both hobbyking stuff. runnink a K40 3 blade (supervee prop) I`ll try it on the 2 blade (same prop) and see if it calms down.
              This boat needs a shaft tear out and replaced with a flex shaft, maybe i`ll get one when i order from OSE for my rigger.
              • JimClark
                • 5907
                How big is the boat. Tha's a lot of power 3600kv
                Billy Graham
                • Boaterguy
                  • 1760
                  24 inches. not much on 3S, its just over 35k rpm unloaded
