3674 leopard for t29?
  • dana
    Banned
    • Mar 2010
    • 3573
    ok so im already bored with the ul-1 setup in there, be great if i were racing but now im thinking about putting a leopard 3674 2200kv, mainly because i think a 4074 might be a little much. is this a good choice for upgrade from ul-1 motor? also is seaking 120 good enough for this motor? thanks
  • dag-nabit
    • Feb 2011
    • 775
    My 3674 1700kv is pulling low 120's for amp spikes on 6S with anS215 prop in the Spartan hull. Averages about 50 60 amps.
    Different hull, different motor, and depending on what you are running for prop and batteries all factor in.
    Gives you a starting point and an idea what to expect.
    Kevin
      The 3674 motor will give a bit more speed than the UL-1 motor - more rpm and it will spin a bigger prop. But the Titan 29 becomes very flighty over 45-50 mph with lightweight setups, you may be overpowering it. If that is the goal then great, although you could always prop down a bit. The ESC may be marginal if you aren't careful with prop sizes, but I suspect it will work as well as Seakings work. Understand that many UL-1 setups pull 80-90 amps as it is.
      • dana
        Banned
        • Mar 2010
        • 3573
        i am def afraid of getting too much. im at 35mph at a good day with my gps, so im pretty sure i can go a little more. i tried an m440 on it yesterday, and im not to sure if i liked it... i kinda figure stick with an x442 or x640 and a slightly better motor. my goal is 45 tops with this one, so yes propping down is an option
        • dana
          Banned
          • Mar 2010
          • 3573
          truth be told, yesterday i got to show my boats off to a fellow boater freind, after the titan, i ran my MM and the t29 seemed like a tugboat lol. that MM is just sick
          • keithbradley
            • 3663
            Kevin
            50-60A? Is that at full throttle??
            www.keithbradleyboats.com
            • egneg
              • 4670
              The T29 should be doing at least 40 and closer to 50.
              IMPBA 20481S D-12
              • dana
                Banned
                • Mar 2010
                • 3573
                but will the 3674 get me there? or 4074... i just dont want too much..
                • Rumdog
                  • 6453
                  The 3674 will definately get you near fifty.
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    thanks. thats what i need to hear. now the 2200kv is 3d, so what would timing be? 0 degrees?
