leorpard 5692 what kv??
  • Make-a-Wake
    FE Rules!
    • 5557
    I'd use the 1340kv on 6s myself................
    • corsamegane
      • May 2011
      • 9
      Hello
      I would like to use the 1340kv motor but I'm afraid to burn down the whole system!
      With this motor and 6s battery, it would reach about 33k rpm and it would be harder for me to get the right pinion gears and the spur gears.
      I have to talk to someone and tell me what is really best not to melt anything or try not to melt ... this is something I still do not know how it works because I understood that there are many variants and it is confusing me a little
        • 9488
        Originally posted by corsamegane
        Hello
        It all really depends on your final gear ratio
        I think you may be over thinking the kv amp thing a bit to much
        if your only looking for 35-40mph I would not waste the cash with two motors and escs
        on one 730kv using 6s would get the low speeds your looking for
        with one 1090kv on 6s should get you 55mph without any issues at all
        these big motors produce some amazing power
        and keep in mind, some of these guys giving input know a thing or two and we are trying to direct you into the right direction
        I think the Baja 5b Castle conversion (730kv) on 6s only pulled an average amp draw of 40 or so amps and peaks of 64amps
        • corsamegane
          • May 2011
          • 9
          Hello
          I know you're right when you say that I'm worrying too much about the amps and kv.
          I will use the 1090 kv motor and I will not bother me further with this thing, I have many other details to worry!
          Thanks for the help and thank you all for your patience!
          I leave here a picture drawn with a few more things!
          An important detail that I changed was that I lowered the motors about an inch into the chassis, so the center of gravity is lower, which improves the stability of the car!
          • tarnold69
            • 133
            the 1340kv with out quistion i have the 1090kv on 8cell if you want to get the full potential of the motors
            • corsamegane
              • May 2011
              • 9
              I sure that with the 1340kv motor it runs faster but the 1090kv is enough for me!
              As already told me here with only one engine the car already flies now imagine two engines geared correctly!
              The brand will be JMFB Steroid, Steroid because the size and power and JMFB are the first letters of my name!
