Too hot still help!
  • liteumup69
    • May 2011
    • 145
    Too hot still help!
    Hey all, Ive got a aeromarine Titan 40, with a 12XL motor, barracuda 125 esc, and Im running it 3s lipo in series. The esc states that it will go up to 6's. The first run I had with the boat the esc got up to 160 F. So I took chris fines advice at fine design and JB welded two brass tubes along side the small heat sink on the ESC. Today I had the boat out, ran it for 8-10 min MAX, I brought it in and the esc was at 160F, the Motor was at 130F, and both 3s lipos were at 90F.. Too hot? seems it. This is my first fast electric, Let me know what what you think, also when the boat was at wot, it "bounced" a bit, maybe lower the trim tabs a bit? heres some pics of the setup.. Thanks Paul
  • Doby
    KANADA RULES!
    • 7280
    LiPos at 90 deg are fine.
    Motor temp is borderline OK....
    Controller temp is to hot....
    8-10 minutes is a long time for running a FE Boat...heat will build up.
    What prop are you running?
    What brand of motor?
    Grand River Marine Modellers
    • liteumup69
      • May 2011
      • 145
      prop is a ocutra x445, and its a blue nemisis 12xl
        • 8012
        Eight to ten minutes is too long for most FE boats without building up high temps. The only thing really hot is the motor, Fiegaos are not very efficient so the high temp is not a surprise. Take a shot of the transom frmo the side sowe can see the strut depth and angle. Also measure where the CG is relative to the transom.
        My Titan 40 races on 4S with a Neu 1521/1.5D at 54 mph - but I'd never run it for more than three minutes....
        • lenny
          • Sep 2010
          • 4294
          How good is your water flow and what kind of a water pick up ?
          ? ONLY IF THEY WORK
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Another bit of advise - don't take advise from fine design. JB Weld doesn't transfer heat either.
            • Doby
              KANADA RULES!
              • 7280
              [QUOTE=LarrysDrifter;322914]Another bit of advise - don't take advise from fine design. JB Weld doesn't transfer heat either.[/QUOTE
              Good point.
              • liteumup69
                • May 2011
                • 145
                Well, after talkin to some folks at rumrunner, the tubes are off along with the JB, There's a fellow on here that sent me a PM who makes custom water cool heat sinks, I thought MY temps had droped but that's not the case, I try the other route, and will post pics of the transom tonite, thanks for the help guys
