2028 Motor Questions
  • crrcboatz
    • Jan 2009
    • 914
    In a typical 45" mono how many amps will a 2028 pull on 10s 4p (aka 4- 5s packs 2 each hooked in parallel x 2) 40c-60c each pack?
    Was trying to figure out what esc requirements would be 4 such a setup. Thinking of trading 1 of my full mod zenoahs for the motor and some cash.
    Curt
  • RIPFENCE
    • Sep 2009
    • 1332
    Curt
    you will need a 240hv esc for sure...curt..the big castle has to be capable of 150 plus constant with near 200 spikes...just taking a guess..but the bottom line is a 240hv for this beast...
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
    • Make-a-Wake
      FE Rules!
      • 5557
      I pulled 180a average on a run with my 50" hydro with a Castle 2028 on 9s.
      • crrcboatz
        • Jan 2009
        • 914
        So the consensus is 240 HV. Ok. Well just wanted to get some good out of a favorite older hull I just love, a 46" Twincraft. It is metalflake green/white bottom with a very cool cowl. It is already drilled and setup so would be a nice fall project. Will begin saving coins for the motor and esc. Tnks!!
          • 9488
          Curt
          I believe that is actually 10s2p
          • b.mcdaniel.2009
            • Sep 2010
            • 1641
            Thats good to know
            ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
            • JMSCARD
              • Mar 2010
              • 3444
              you are absolutely correct brushless... to make 10s4p would require either (4)10s packs in parallel... or (8) 4s packs... 2 each in series then parallel'd up...
              the op's setup is actually 10s2p...
