Pursuit Flipped
  • tanasit
    • 65
    Pursuit Flipped
    X447/3 Leopard 4082: 2000kv
    Both battery packs were placed by the motor's sides.
    Trim tabs are leveled with the bottom and the strut was about 2-3 + degree.
    Either 4S or 6S it did the below:
    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
    Plan to relocate the packs and set the trim and strut to fix this.
    Any suggestions will be greatly appreciated.
    Tanasit
  • steveo
    • 1454
    level your strut to be parallel with bottom of hull and about 3/16-1/4" above the keel, and strat with you batts at 30% cg and move them foward if need be
    • martin
      • 2887
      Couldnt agree more, You deff dont want to have 2-3 degrees + on the strut. Set it at 0 degrees & try again, You might find that you may need to put the tabs down a bit as well.
      • tanasit
        • 65
        I tried with 0 degree, but it's slower and the amp went up to around 150, no flip though. I guess the prop may be too big, so I will try smaller ones later.
        BTW, the 30% is from the bow to stern or up to the rudder?
        Thanks for the help,
        Tanasit
        • ray schrauwen
          • 9472
          Prop is a tad large for 2000Kv on 4S.
          • ron1950
            • 3024
            my pursuit is 0 degrees strut, batteries like yours beside the motor, trim tabs nutral and a m445 prop...no blowovers and about 50 mph with 4 cell
            • steveo
              • 1454
              Tanasit
              your cg is from the back of the hull foward ( stern to bow)
