grapner Mini-JET in a 26" mono
  • video200
    • 837
    Anyone who have experiance with the graupner Mini-JET http://www.graupner.de/en/products/1...tab=spareparts and know how it might work to power a 26" mono ? http://www.raidentech.com/3827-new-racing-boat.html
    yes i know its not worth the money. but it have given me alot of joy over the years and worked great as a rescue boat so there are some sentimental reasons :)
    Klaus
  • TheShaughnessy
    • 1431
    I'd go with the 29 mm jet. Had one in a 29" mono and it was pretty fun, should be a perfect match for a 26 inch.
    • video200
      • 837
      what kinda speed did you get out of that ? speed is never a bad thing even for a rescue boat:D
      • TheShaughnessy
        • 1431
        i guess it went 20 mph on a good day, 15 or so??
        • video200
          • 837
          thats cool TheShaughnessy :)
          best price i can find for the 29mm though is $78 with the steering\reverse mechanism. blows my budget away fast
          • damfurst
            • 261
            Klaus
            That boat appears to have a transom that is 90 degrees to the hull. This helps to make it a good canidate for the mini jet drive. I'm sure it would work in that hull. It would be no speed demon but would work well enough for a rescue boat. If you want more speed go to the 29mm drive. What are you planning on powering it with?
            • video200
              • 837
              my first thought was to use a feiago 9L on 2-3S or a 8XL on 3-4S.
              • damfurst
                • 261
                I think either of those motors would work on 3s best. The 9L would be a direct bolt in. The 8XL would need an adapter froim 380 to 540 motor size. 2 things to look for though are 1. The motor mount is the weak part of that drive (broke mine as others have also) and 2. The u joint supplied may come apart from the extra torque of the brushless motor. I've mangled 2 of them others though have reported no problem. Should be a good build though. The Graupner kit is much desired for it's quality. The Nqd one is basically a knock off of it, but still a good hull.
                • video200
                  • 837
                  thank you damfurst. 9l it is then :)
