Trim tabs and turn fin height
  • Brushless01
    • Apr 2010
    • 487
    Hi guys,
    Today im going to install trim tabs and turn fins on my HOR Prince 25 and was wondering how high from the bottom of the transom should the tabs be mounted ? Also should the fins be mounted at the angle of the vee of the hull ?
    Thanks
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • martin
    • 2887
    Mount the tabs around 1.5-2mm up from the hull bottom, Dont mount them level. Turn fins should be at 90 degress to the hull bottom, So looking at the transome of the boat straight on both fins are angled out whilst rudder is upright to give some idea as to what i mean by angled out. Looking from the side of the boat swivel them on the bolt to around 45 degrees as a starting point. Or simply look at pictures on this site of boats rear end shots, Its allways easier than explaining what you mean. Martin.
    • Rich
      • Jan 2008
      • 551
      Martin, does the 1.5-2mm up from the hull bottom apply to all trim tabs on any boat?
      • martin
        • 2887
        I believe most fit tabs above hull bottom, You get less drag.
