Lipo & esc wire length
  • martin
    • 2887
    I know wires should be as short as possible, In my case i have a 15" mini mono that runs 3s 60c & 42000rpm unloaded at around 50mph on octura metal x435. So its quite a hot set up. Will it make a difference using shorter wire on lipo & esc bearing in mind because every thing is so close together because of its small size. Lipo wires are 4.25" but i could reduce them to 2" or is that not worth shortening. Thanks Martin.
  • Make-a-Wake
    FE Rules!
    • 5557
    I wouldnt mess with 'em.
    • sailr
      • Nov 2007
      • 6927
      You can shorten the battery wires but NOT the motor wires.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • martin
        • 2887
        Yes i wouldnt shorten motor leads as most know the reasons not to do that, But didnt know whether shortening the battery wires 50% would make any difference as their only just over 4" to start with. Martin.
          • 9488
          you honestly won't see any difference in this setup
          but having bullet connectors and great solder joints you will notice a difference as those will have lower resistance
          • martin
            • 2887
            Yes i always use bullit connectors even on this small stuff. Martin.
              • 9488
              then your set
