can i take away the teflon and go up 1 size in flex ?
  • video200
    • 837
    as the title say. i have a .150 flex with teflon now. can i remove the teflon and just put in a .187 flex in its place or wil that not work ?
    klaus
  • dasboata
    • Dec 2010
    • 3152
    yes,,,,, alot of guys do run without a teflon liner
    • video200
      • 837
      thank you dasboata
      so the tube size wil fit then :)
      • dasboata
        • Dec 2010
        • 3152
        As long as the 3/16 flex cable has some wall play in it ( not tight ) you will be fine there is a .037 difference between 150 and 187 What is the ID/inside diameter of the brass ??
        • video200
          • 837
          the brass should be "1/4" brass for Octura .150 Teflon tubing."
          bought it from steven a few years ago. but ripped the proppshaft from the flex today
          • dasboata
            • Dec 2010
            • 3152
            1/4" ID will be fine
            • video200
              • 837
              thank you dasbota :)
              klaus
              • 6sHyper
                <<<Surfs up!
                • Jan 2011
                • 597
                1/4" is too big for .187 flex IMO, 7/32 is perfect with no teflon liner. What i have done is just put some epoxy on the outside of the 7/32 and stuff it inside the 1/4" its a perfect fit.
                • video200
                  • 837
                  there is 1,58mm or 1/16 difference between the 7/32 and a 3/16. how much difference wil it make ? worst case im just stuck with using teflone.
                  • dasboata
                    • Dec 2010
                    • 3152
                    what is the ID of the brass ????
                    • video200
                      • 837
                      http://www.offshoreelectrics.com/pro...rass-tb&cat=70
                      i got the 150 WITH teflon
