Twin Motor Mono Question
  • b.mcdaniel.2009
    • Sep 2010
    • 1641
    What's some pro and con's on having a twin powered large mono? Thinking a 47" Promise hobby deep V with either 2 Leopard 5692 1090kv W/ Castle HV ESC's or on a budget 2 Castle 1717 1580kv W/T-180A. ESC's.
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
  • sundog
    Platinum Card Member
    • Feb 2009
    • 878
    If you mean surface drive, wouldn't one prop be out of the water when it heels over in turns? That might be hard on the esc, methinks!
    Maybe not! Check this out: http://www.youtube.com/watch?v=Gl6Yg...eature=related
    Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
      • 9488
      I think the twin 1717's would get it done real nice!
      not sure of the speeds your looking for, but it should be fast
      • b.mcdaniel.2009
        • Sep 2010
        • 1641
        I think as long as the drives are mounted close together the props should stay in the water I would think?
        • b.mcdaniel.2009
          • Sep 2010
          • 1641
          60-70MPH would be fine!
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7119
            pros: very cool, motors/esc working half as hard, you have a back up in case one motor/esc/driveline/prop fail, that sweet sound of double power, no torque roll
            cons: more batteries, twice the wires, twice the maintenance, limited by sizes of CR props, a lot of cash gets dumped in.
            "Look good doin' it"
            See the fleet
            • sundog
              • Feb 2009
              • 878
              I bet!! Yes, Jesse J. was considering staggering the motors to get the stuffing tubes as close together as possible and encountered an interesting sympathetic 'assistance' phenomena http://forums.offshoreelectrics.com/...ighlight=jesse. Quite interesting - might even use less amps or get more torque because of it.
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7119
                Interesting, yes. I have been thinking about that experiment and have some further insight. I have yet to try unplugging the Y connector for the ESCs. I am suspecting that the sympathy was cruising down the Y connection - power from the powered motor to the unpowered one along the radio wire. Still sympathetic, but maybe not related to the magnetic field. I have NOT observed this phenomena with inrunner motors ever! I don't think there will be anything for free, except maybe some "cushioning" - maybe bad on ESCs? probably not, but need data to be sure. Anyone with two Eagle Trees?
                See the fleet
                • sundog
                  • Feb 2009
                  • 878
                  I don't think so. Since the motor was disconnected it was totally sympathetic, the esc's weren't involved. The outrunners, having the magnets under the outer spinning can is what I suspect allows/causes this. This is quite an interesting (phenomena) - it'd be nice for someone to build/use this idea - it has merit. Anything that can save amps or give more power for the same amps is always cutting edge!
                  • H2OCamel
                    FAST ELECTRIC EVERYTHING
                    • Oct 2007
                    • 484
                    Jesse i think I have four eagletree's need to borrow 2? ;-)
                    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                    • Jesse J
                      scale FE racer
                      • Aug 2008
                      • 7119
                      Hey Chris, if you lent me one, I would then have two and could perform the experiment. pm on its way.
                      If you have one with 5.5mm bullets, that would be best. thanks!!
                      See the fleet
                      • sundog
                        • Feb 2009
                        • 878
                        • b.mcdaniel.2009
                          • Sep 2010
                          • 1641
                          Wowo way over my head LOL.....Going to be innrunner's if I go ahead with this build. Glad you chimmed in Jesse, I know you've built a few twin powered mono's lol.....
                          • H2OCamel
                            • Oct 2007
                            • 484
                            It on it's way! Can't wait to see the data.
                            • b.mcdaniel.2009
                              • Sep 2010
                              • 1641
                              Anyone else have any thoughts?
