1717 Mount For 4" Rails
  • b.mcdaniel.2009
    • Sep 2010
    • 1641
    Who makes a "RAIL" style mount for a Castle 1717 for 4" rails? Wanting to build a DF 35" Mono this time.
    Which ESC for the 1717 1580kv for 5-6s?
    The New Castle 240 Ice?
    Or the trusty T-180?
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
  • HOTWATER
    • Nov 2008
    • 2323
    you can try here for the rails... ---> http://southriverrcboats.com/shop/ca...aram=cid%3D%26
    I would say the new Ice for the ESC if you are going 5S to 6S....
    -Kent
    "Will race for cookies!"
    IMPBA D12
    My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
    • b.mcdaniel.2009
      • Sep 2010
      • 1641
      Thanks Kent.
      • K.R.Joye
        • Feb 2010
        • 1046
        Don't rule out the ETTI Competion Race 150 amp. I'm currently running a 1717 on 6S in a AC Sport 40 on 6S1P. The ETTI is working out great! South River & OSE carry them.
        ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
        ****2008/9 MMEU LSO, 2008 LSH CHAMP****
        ~~~~~~~70 MPH Club Member!~~~~~~~~~
        • 6sHyper
          <<<Surfs up!
          • Jan 2011
          • 597
          why not just go with the swordy 240??
          • b.mcdaniel.2009
            • Sep 2010
            • 1641
            What speeds are you getting with that setup?
            I never had a ShordFish ESC...Castle is my favorite other than the T-180, because there easy to program and there warranty department is A+ IMO....
            • K.R.Joye
              • Feb 2010
              • 1046
              Just started testing props ill get some GPS readings soon, est low 60s so far.
              • b.mcdaniel.2009
                • Sep 2010
                • 1641
                Looking more at the 1717 mount from South River, Its states the rear is two machined pieces to clamp on to the motor cooling fins, Is this going to work with a OSE Jacket?
                • 6sHyper
                  <<<Surfs up!
                  • Jan 2011
                  • 597
                  dont think so Brad, the jacket covers all the fins on mine
                  • Scott T
                    • Oct 2007
                    • 590
                    You could try one of the new ones from fastelectrics.com. This is one with a 1717 Air mounted in a DF21 mk2 mono. Very solid mount, I'm not concerned that the back of the motor isn't supported, I seriously doubt it will flex.
                    Scott Tapsall
                    Pine Rivers Model Powerboat Club - Facebook Page
                    My Gallery
                    • K.R.Joye
                      • Feb 2010
                      • 1046
                      From my experience with the 1717 it doesn't require cooling if you have your setup optimized. I only cool the esc in my 1717/6S1P powered Sprint Cat & AC Sport 40. I use 1/8"Aluminum L-Bracket mounted to the bottom for both, plenty strong. I can see your point needing a rail mount for a mono application.
