Leopard 4082 1500 kv with an x642 prop......imagine if I could keep the same strut angle and run an m445? Running a larger prop the strut needs to be dropped so speeds aren't as good. An offset rudder kit I think would work...hmmmmm.
Hit 60 mph on my genesis today...
Actually you may find more speed with the x642 over the m445... sometimes it's all about the pitch -
My poor friend bosnicali lost a boat today....maiden voyage, was running good and then hit a wave or flipped and then splash, went under and we figured no big deal but it never came up.. Had foam in the front too but still sank..Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
(63.7 MPH) Traxxas Spartan (same setup)Comment
Thats the genesis i built dale, he is working bugs out of it, i told ya that boat will turn some good times, with the thru hull pickups i know its slowing her down some, some more adjustments and she will flyComment
Ya I could squeeze more out of her but I'm happy with mid to upper 50's and today's 60.0 run.....
Packs can go back more and strut could go up a little further. Thanks Dan, I love it.....I think it turns fine, I have no complaints...Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
I have a Fightercat genesis hull en-route and will be setting it up with the same motor and ESC.
Have a few different props to try, including an x642, so now I have an idea what to expect.
Too bad about the loss of the bosncali's boat. No way to try to recover it?..... safely.
KevinComment
NOTE TO SELF...always tape hatch!!!Comment
he had her running pretty dam good to.....she must of been taking on some water from somewhere, he had lit taped up so that rules that out, im thinking the shaft was pulling water in somehow.....gezzzzzzz.....that was a cool hull too, he was getting 40 some mph and said she handled great.Comment
Dagnabit...the problem with larger props is that the prop will hit the strut so u need to angle it down and that looses speed.....keep me posted, just got mine so let me know what u do and upgrade? Dan, that stinks. What broke?Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
Gibbies, I haven't used hatch tape on my genesis...I'm afraid of the clear coat peeling but I'm trying to see if hockey tape or the hatch tape from ose will peel the clear coat. I guess clear coat peeling is better than loosing an entire boatGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
