380 xl feigo motors
  • dano1
    • Dec 2010
    • 403
    380 xl feigo motors
    Any opinons on the feigo motors for a twin 34in cat?, want to finish this project, running 60 amp seakings esc's and want to know max battery size i can run thru theses esc to motors, currently running 3 cells 5000 packs....not interested in super fast speeds, just want it reliable for play, thanks guys!!!
  • Make-a-Wake
    FE Rules!
    • 5557
    Why not go with a couple of silky smooth 4 pole 2860 Leopards..............?
    • Igoreski
      • Apr 2010
      • 77
      I will second that because I had twin 380 8XLs on 3s and they are fast but draw too many amps for that ESC.
      • BHChieftain
        Fast Electric Addict
        • 1969
        FWIW I'm running a 380 10xl on 3S on a 22" tenshock mono1 with a used 45amp proboat fastech ESC-- running nice and cool.
        Chief
        • Dragboatdad
          • Jan 2011
          • 28
          I am using 2 380 10xl with seaking 120 esc on 3s and 4s with no problems. I upgraded a venon ekos after all the stock stuff burned up. I got 48mph on 3s and 57 on 4s. I am using wire drives with x442. Now it's very reliable.
          • JPriami
            N4FOX
            • 1675
            Im running two 380 9xl's in my ekos clone the "saga" and two 80amp esc's on 4S per motor. they run good and temps are good.
            • dano1
              • Dec 2010
              • 403
              how about the run times on those feigo's ,,, what are ya geing play time wise
              im running 60amp esc seakings, whats the max i can put into them battery wise
              • Dragboatdad
                • Jan 2011
                • 28
                I don't know about the 60 amp esc, I'm sure it's fine, the 120's I use are overkill for peace of mind.
                I get long run times with moderate temps(100-120) without hitting low volt cut off
                Someone else here is more qualified to help you with battery capacity then me.
                • dano1
                  • Dec 2010
                  • 403
                  well i did mange to run her today with the stock motors....dont ask why its running now, adjusted the stingers more and she ran pretty good till mudder nature decided to start blowing again.....still planning on new motors but still wondering how large of pacs i can run safe on those esc's, would like to run 4 or 5p, currently running 3p but still dont know if esc can handle the load, prolly gonna go with a pair of feigo's, not gonna dump alot more into this project, thanks for the info on the motors gents!!!!
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    I assume you meant 4 or 5s. The 60a Seaking is rated for 6s according to the info i have seen............. the 2700 to 3000kv motors need only 3s. The 380 8xl's can get up near the 60 amp range...............prop accordingly if you go with the 8xl.
                    • Pwb201
                      • 214
                      I was running the stock esc's 60 amp in the ekos with x442 and the feigos. Too much prop wound up frying the esc's but knew it was gonna happen so purchased the 120 turnigys but haven't run it yet. Also upgraded all connections to 5.5 bullets as the deans couldn't handle draw. Hopefully I've worked all the bugs out as I still would like to run those 442's. Oh yeah by the way Speed was 63mph and as sturdy as could be. That's perfect glass conditions. Little chop and you have to throttle her but that's what they make bigger hulls for.
                      • Dragboatdad
                        • Jan 2011
                        • 28
                        I have the same set up, that's great speed. I only got 57. I'm using venom 3200 30c 4s, what batteries are using? I get 48 on 3s 3000 40c turnigy. Also using ec5 connectors
                        • JPriami
                          N4FOX
                          • 1675
                          I get 62mph out of mine on 4S nanos and 40mm CF props.
                          • Pwb201
                            • 214
                            Hey Im running the blue lipo batteries 5000mah 4s packs. I think I need more coolant though. Any suggestions?
                            • Dragboatdad
                              • Jan 2011
                              • 28
                              I'm using the rudder pick up to cool the esc, drilled another hole in transom and put a Y inside to cool both esc. New additional outlets on both sides. Using the two stock pick ups, one for each motor and motor mount to stock outlets. The batteries get warm if I run too long but everything else stays below 120.
