Motor upgrade??
  • pribco
    • Feb 2011
    • 109
    Motor upgrade??
    Am wondering is a small motor upgrade might give me a bit more oomph in my Skidaddle TOO. Have already upgraded prop. If possible want to avoid expense of brushless which means, I think, needing a new ESC.
    Current motor-
    Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
    Would this be better?
    or this??
    http://www.offshoreelectrics.com/pro...?prod=grp-6312
    Any advice from the experts??
    Pribco
    If you step on my tail, you had best make plans to deal with my teeth!!!
  • Boatman
    • Jan 2008
    • 796
    post a link to the boat or some specs. You will find brushless upgrades for smaller hulls are just as inexpensive as brushed now. However you are correct about the esc. You would need a new one. Hope you get your info
    • Boatman
      • Jan 2008
      • 796
      Found your build thread...
      http://forums.offshoreelectrics.com/...d.php?p=306911
      • pribco
        • Feb 2011
        • 109
        Lordy, Lordy, one can sure spend some cash on this hobby, can't one??
        • Alexgar
          • Aug 2009
          • 3534
          I would go with the sp 600 as it has replaceable brushes a high matinence item in these motors
          • CaptPJB
            • May 2010
            • 237
            Upgrade?
            How about a Electrify Speed 600 about the same price as the Titan. Guess it might depends on what voltage you are running.
            Scroll down here http://kintecracing.com/RIO_EP.html
            Always wondered myself about Titan vs Speed? I put a Speed in my Rio and am quite happy 18-20 mph ( estimate)
            • pribco
              • Feb 2011
              • 109
              Standard 7.2 volt mi battery.
              Question is--will any of these suggestions help with speed??
              • CaptPJB
                • May 2010
                • 237
                My opinion is the Speed 600 would be better, I have not run a Titan but have read of issues, hard to quantify as they have several winds/turns so I may be dishing them unfairly..
                S600 a solid choice and proven good price too.
                Peter
                • pribco
                  • Feb 2011
                  • 109
                  I am about to order a couple S600 motors.
                  The output shaft is 3.175mm--the coupler(s) I have are for 3mm--do you think the shaft will fit??
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    The speed difference you may get with another 550 size motor will be so minimal it will barely be noticed.................could be like 1-3 mph difference.
                    You should go brushless..............you'll end up there anyways................we all do!
                    Here's an inexpensive setup:
                    http://www.hobbyking.com/hobbyking/s...idProduct=9764
                    http://www.hobbyking.com/hobbyking/s...idProduct=8946
                    Run it on two 6 cell nimh packs in series if that is what you have available for batts.
                    • CaptPJB
                      • May 2010
                      • 237
                      Got to agree the increase if you stay brushed is small, essentially the cost of the upgrade is the esc, look at it as an investment for future boats upgrades. Brushless really is the way to go.
                      My Rio remains brushed as the hull really will not take high speeds so keep it a "guests" use boat rather than put more money into a limited hull I bought a new boat with further upgrade potential.
                      Peter
                      • blizard05
                        • Jun 2007
                        • 576
                        Bill, try to find a used SV27 setup Larry
                        America home of the free, thanks to the brave [/url]
