help
  • ctstike
    • Feb 2011
    • 32
    help
    hi dont know what to do first, which one i supposed to do 1st program the controller
    (esc) or do the timing for my motor? and how can i do the timing for my feigao motor?
    tnx
    PUSH the PEDAL to the METAL
  • Diesel6401
    Memento Vivere
    • 4204
    The controller (esc) does the timing. All you have to do is properly configure the esc.
    - Which esc are you using?
    - What boat?
    - What exact motor? Got the Feigao part, but what size/kv rating?
    - What batteries & number of cells?
    - Diesel's Youtube
    - Diesel's Fleet
    • ctstike
      • Feb 2011
      • 32
      its twin brushless motor catamaran, 120amps esc 2x 380 9xl 2x
      2x 5s turnigy 30cell
      • ctstike
        • Feb 2011
        • 32
        120amps turnigy
        • Diesel6401
          Memento Vivere
          • 4204
          Whoa... WAAAAY to much voltage. Those motors are 3s motors, not only are those 5s batts going to burn them up voltage wise the unloaded rpm would be over 50k which exceeds the bearing rating . Don't use those batts. Something is gonna blow!
          120amps turnigy
          Which turnigy esc? There are several different manufactors, hk just sticks a label on them. They don't actually make them. Do you have the link.
          - Diesel's Youtube
          - Diesel's Fleet
          • 6sHyper
            <<<Surfs up!
            • Jan 2011
            • 597
            yeah like he siad 3s motors, timing should be set at 7.5 for them.
            • ctstike
              • Feb 2011
              • 32
              i dont have the link boss but all i know is 120amps turnigy thats all! and how come some fools use 4s, 6s, 5s for that feigao motors? with the same 380 9 or 10 xl?
              • Diesel6401
                Memento Vivere
                • 4204
                People run those voltages on a 540 9xl or 10xl.
                I could see running 4s because it's still ok rpm wise on a twin but 5s or 6s on that motor is just bad bad BAD news.
                It's hard to help you with programming your esc if your not sure what esc your have. Just saying it's a Turnigy doesn't help at all. Is it a Turnigy Marine or Turnigy Aquastar, they are 2 COMPLETLY different esc's but both say Turnigy.
                http://www.hobbyking.com/hobbyking/s...idProduct=8946
                http://www.hobbyking.com/hobbyking/s...dProduct=10626
                - Diesel's Youtube
                - Diesel's Fleet
                • ctstike
                  • Feb 2011
                  • 32
                  its a 120 amps turnigy marine boss! it help u out a little bit? and one morething about the programing and timing do i have to buy a device for that? im a beginner dont know about this stuff,,, tnx
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    Yes that helps a TON.
                    You can program buy your radio by listening to beeps which sucks. Here's the easier way, now that we know what exact esc you have we can point you to the correct program box and setup.
                    Here's the box: http://www.offshoreelectrics.com/pro...-seaking-pcard
                    1) Forward only
                    2) Manually enter you cell count. don't rely on the auto calculate it doesn't work for beans
                    3) 3.2v
                    4) 7.50
                    * Once you get the programming card that stuff above will make more sense.
                    Here's your manual http://www.hobbywing.com/upload/manual/HW-15.pdf
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • ctstike
                      • Feb 2011
                      • 32
                      listening to that beep is suck boss! this is so complicated to me i dont know u think u can call me boss?
