Hydra ice HV owners, heads up.
  • johnson22456
    Counting down the days...
    • Jul 2008
    • 218
    Recieved my hydra ice HV earlier this week from Steve. Looking it over before installation noticed the caps were 2 different ratings. One was 470uf 50v and the other was a 680uf rated at 35v!!! Called castle and there sending a new one out.
    Luck was on my side and fortunately I didn't smoke this new esc.
    I just wanted to give you guys a warning before powering yours up.
    Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
  • Steven Vaccaro
    • 8721
    thanks for the heads up! And sorry for the problem!
    • siberianhusky
      • Dec 2009
      • 2187
      The difference in capacitance doesn't matter, if they are in parallel you add the values together.
      The actual formula for caps in parallel is C1+C2 etc.
      Be a bit too close for comfort though with a 35v cap on an hv esc!
      Would be fine if they were both 50v.
      • m4a1usr
        Fast Electric Addict
        • 2038
        You are one lucky guy for bothering to take a look at the rating and values on that speedo. I'm hoping what you got was sheer bad luck or circumstances beyond quality control. A high voltage speedo should have at least 50 volt caps but even thats not safe on 12S volts. Should be using 63 volt caps. At least you caught it.
        John
        Change is the one Constant
        • Himalaya
          • Apr 2009
          • 251
          A 470uf 50v and a 680uf 35v are same in size for a given product series, this could be the reason for CC having mixed them up.
          I agree with m4a1usr that 63V capacitors should be used in 50V systems, there used to be a rule in EE to leave at least 20% voltage margin, especially for electrolytic capacitors. Probably CC just wanted max capacitance within the limited space.
