Converting 2 battery ESC to single battery
  • slappy
    • Feb 2011
    • 34
    I have a spare ESC from a SV27R lying around which I'm thinking of putting in one of my small 22" arowana builds.
    Can I chop one of the leads off and re-connect to make it a single battery setup?
    I could run a small 3 or 4 cell single instead of the 2 x 2cells recommended?
    Pic below.
  • blizard05
    • Jun 2007
    • 576
    Pic below.
    Don't cut it off, use a jumper on one lead
    America home of the free, thanks to the brave [/url]
    • siberianhusky
      • Dec 2009
      • 2187
      Mine are long gone, bullet connectors now that go in into a custom harness. Won't hurt a thing, in fact it's recommended to get rid of those stock connectors. They don't handle too many amps without heating up.
        That controller will not work on 3S. It has a 4S low voltage cutoff which will not allow the controller to even turn on with 3S. But you can use it with a single 4S pack, I do that all the time.
        • sundog
          Platinum Card Member
          • Feb 2009
          • 878
          Fluid is right - the esc is wired for series, not parallel. You can't just cut one off or jumper it - it won't have the voltage necessary to operate.
          Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
          • siberianhusky
            • Dec 2009
            • 2187
            As long as you run a single 4s pack you will be fine, if you want to run two packs in series it would have to plug into a harness that connects both batteries in series then plugs into the esc.
            My old style SV esc only has a positive wire and a negative wire coming off it each one has a 5.5 bullet connector.
            I bought the boat used, to tell you the truth I didn't even know they came from the factory wired like that! Just assumed they all plugged into a separate battery harness.
            Thought they all had two plain leads coming off.
            • slappy
              • Feb 2011
              • 34
              Cool, single 4s and jumper it is. Its only 45amp but will keep it as a backup anyhow. Will need a low voltage cutoff too.
              • yurkanip
                Banned
                • Jul 2008
                • 420
                to use a single 4s pack, you don't need a jumper. Its straight esc to battery, positive to positive and negative to negative. You only need a jumper if you are wiring in Series, which was it's original configuration. Hope this helps.
                • sundog
                  • Feb 2009
                  • 878
                  Yes, he'll need a jumper at one of the Deans to close the circuit. Or better yet, cut all that cr*p off and solder on a set of 5.5mm (or larger) bullets.
                  • TheShaughnessy
                    • 1431
                    This is an easy fix. Just copy the picture. If you are going to use deans ( wouldn't recommend it) make sure you solder + to + and - to - cause in my pic they are reversed.
                    Hobbyking has 5.5 mm bullets in stock right now, you may want to order some up. get the ones that start with am for the part number.
                    You may be able to disable the lipo cutoff for the esc and use 3s then just have a separate lipo cut off, but i'm not sure if it will arm with only 3s power.
                    • yurkanip
                      Banned
                      • Jul 2008
                      • 420
                      No reason to use two deans connectors with one lipo. Shaughnessy drew a picture exactly as I was describing. Good job. and as many have mentioned, do not use deans...go to Bullets. I have personally melted Deans and solder off of them, in a 3s setup pulling low amps.
                      • sailr
                        • Nov 2007
                        • 6927
                        I use 5.5mm gold bullets on everything.
                        Mini Cat Racing USA
                        www.minicatracingusa.com
                        • Alexgar
                          • Aug 2009
                          • 3534
                          Do think there is a lipo cutoff on the 45 amp version only the 60
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            The SV27r esc is the same esc as the orignal with a different cooling jacket and larger cap. There is no LVC installed on that esc. Actually in the picture you can see that it only says nimh/nicad. Should work on 3s just fine. Just know there will be no LVC protection unless you install a lipo shield
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • TheShaughnessy
                              • 1431
                              for some reason i though this was the ul1 60 amp version. So yeah 3s should work, but no lipo cut off.
