Miss Geico: 8 or 10 with 5.5 bullits
  • Ripper
    • 65
    Hey guys, I could use some help. I'm new at FE I just got Miss Geico and 2 turnigy 2s1p 4000mAh 40c batteries. The batteries have 8awg wire and the boat has 14awg. After I get used to it I'd like to try and make it fly, T180 esc, 2x3s etc. Just like alot of the other guys are doing. Should I just change all the wires to 8awg with 5.5 bullits or is 10 or 12 wire enough.
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Just use the wires that come on the T 180. They come with 10awg on them. You will have no issues with the wires.
    • Ripper
      • 65
      Thanks, I wasn't quite sure what to do. For now I'll put 5.5 bullets on the 14awg that come on the stock set up (remove the Deans) . The batteries I got have 5.5 bullets.
      Thanks again, post when I get her in for a maiden run. I'll be happy to start with 35mph.
      • Ripper
        • 65
        Thanks, wasn't really sure what to do. I'll put 5.5's on the esc to replace the deans. I did get an x642 to start with, Be nice to get 38 to 42, maybe wishfull thinking. Just leave everything stock for now until I cook something.
        Thanks agian. I'll let you know how I make out on the maiden run.................
        • LiPo Power
          DJI Drone Advanced Pilot
          • May 2009
          • 3186
          Do offset next if you have nothing to do over the weekend...
          Canada
          • Ripper
            • 65
            I have the kintec v2 offset but haven't put it on yet. I've been reading pros and cons. Thought I'd run it stock first and then install the offset.
            • Nor Cal Chris
              • Feb 2011
              • 41
              5.5 bullets on every connection and a kintec offset rudder and a X642, once you get comfortable with running that set up try a M445 prop!
