Freya 36" 2 x neu 1521 + 2 x castle hv 240
  • rogsto
    • Mar 2010
    • 7
    My latest build...... Should be pretty fast.....??
    2 x neu 1521 1D kv 2900 + 2 x castle hydra hv 240
    2 x Octura 450/3
    Turnigy nano tech 2 x 5S 5000mah 45-90 C
    4,8-5 kg
  • RaceMechaniX
    • Sep 2007
    • 2833
    First welcome to OSE and a solid build you have there. Yeah, it should be pretty fast, just make sure to sharpen and balance those X450/3's
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • rogsto
      • Mar 2010
      • 7
      Thanks,, oh yeah that is already done...
      • DISAR
        • Aug 2007
        • 1072
        nice boat!
        http://www.rcfastboats.com/
        • TotalPackage
          Banned
          • 601
          Real nice. 450 3's? How does it run with those?
          • Killer V
            6TH Season Builder/Racer
            • Sep 2010
            • 147
            That is one smokin build. It has to be insane fast. This can't be your 1st build, with workmanship like that. I would like to see some of your other boats.
            Good luck,
            Killer V
            • rogsto
              • Mar 2010
              • 7
              Thanks, i have done som test runs, i am going to install a GPS to mesure top speed. So far motors, ESC is cold. I am also going to do more test runs with different props.. Any prop suggestions?
              I have som cosmetic issues i will resolve, when it is done i will post new pictures..
              It is my 2th build, my first was a 32" cat with neu 1527 1d.
              • DISAR
                • Aug 2007
                • 1072
                What Kv are the motors?
                • rogsto
                  • Mar 2010
                  • 7
                  Motors : 1D kv 2900. it should be able to handle 5s lipo, but maybee the props are to large...
                  • DISAR
                    • Aug 2007
                    • 1072
                    your boat must be very very fast at these rpm with these props.
                    I wouldn't go any bigger on props, there are some options to try
                    octuras 447
                    propshop 4518/3 or 4518/4
                    HOPF 445/3 or 448
                    • rogsto
                      • Mar 2010
                      • 7
                      Yes i would like to go down on prop size, to see if i can get more RPM out of these motors.
                      It seems that most twin cats use 3 bade props. Cats with single motor use 2 blade props, do you know why?
                      • DISAR
                        • Aug 2007
                        • 1072
                        Not really, but I think it all depends on the boat setup and water conditions.
                        Personally, when I setup a boat I test 4-5 propellers to see which gives
                        better overall handling-stability
                        better speed
                        low amps
                        In most of my boats, (twin 135, DF35" & mean machine) the 3 blade props gave me the best results. It's all about testing. The Octuras need some work on them and then can increase rpm, such as
                        make the "angle" tongue to a nice round shape
                        remove some material from the trail edge-backcut
                        • DISAR
                          • Aug 2007
                          • 1072
                          Hopf also has 448/3, I would try them
                          • rogsto
                            • Mar 2010
                            • 7
                            thanks! where can i buy them?
                            • DINO7
                              • Jan 2009
                              • 162
                              H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                              MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                              BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
