Mean Machine and LSO "Need setup"
  • T.C.
    • Sep 2009
    • 236
    We have one of the water damaged Mean Machines and are wanting to run it as a LSO at the NATS .
    We can go either SV or UL power, the boat has a 1/16" wire drive installed with the motor mounted very close to where the gas engine was.
    Radio box has been removed and carbon fiber matt floor epoxied in place.
    Anyone have a good CG, battery placement, prop size, strut angle and depth ect......
    We would GREATLY appreciate some help !!!!
    Thanks T.C.
  • dana
    Banned
    • Mar 2010
    • 3573
    ul-1 power would be faster. x440 prop would be a good start. batteries 9 1/2 from transom in the sponsons. i set my strut so the center hub of the prop is right in line with the bottom of the sponsons . thats jmo. i built one over the winter, used a bigger motor but heres the thread if you want to look http://forums.offshoreelectrics.com/...ad.php?t=20769
    • steveo
      • 1454
      i'm sure with proper setup both combos will result in equal speed, i would start with strut 1/4" above the sponson, i am currently setting up a lso cat for the up coming event using a proboat 1500 kv and x445 prop still needs work , the strut right now it is 3/8" above sponson but it is a different design than the MM
      • Skipster
        • Apr 2009
        • 106
        my MM is a Nautiboyz rebuild
        now running an 1820kv FSD motor
        strut top at 5/15" above sponson level
        prop Octura X437/3
        COG 8.75" from transom
        Batteries 5s1p
        ran this morning on a 1" chop (smooth for here)
        boat was bouncing so I moved the
        Batts up 1 inch
        COG at 9,5
        and re ran the test
        boat leveled out and was not running wet
        results:
        30.5 mph GPS
        80.5 A on Watts meters
        98 *F motor
        95 *F esc
        You can lie to mother Nature
        but You can not fool father Physics
        The more I learn, the more I know I don't know
        • steveo
          • 1454
          look at these threads
          http://forums.offshoreelectrics.com/...earchid=467292
          • T.C.
            • Sep 2009
            • 236
            Thanks for the replies:
            We have tried both the SV and the UL motors, with the same results.
            It is running wet and we cant get it to bring the nose up, we have a x442 prop on it and was advised to lower the strut ?
            If we can get the thing to loosen up I think it will run, this being our first cat type boat ,we haven't a clue ?
            Again this is for LSO to run at the NATS so any advise or real life experience with the boat and same motor setup would be great.
            T.C.
              • 9488
              My CG is at 8 1/2" from transom and the bottom of the strut is 1/8" above the bottom of the sponsons
              works good for me
              • Reed Eagle
                Reed Eagle
                • Jul 2008
                • 7
                Terry,
                Try setting the c.g. at about 30 per cent from the transom and the center line of the propshaft at 3/16"-1/4"
                This should help.
                Ol' Reed
                • T.C.
                  • Sep 2009
                  • 236
                  We got the CG correct, I think were missing the prop depth ?
                  I'm sure were below the bottom of the sponsons.
                  That will change this week.
                  Thanks Guys !!
                  T.C.
                    • 9488
                    Looking forward to hearing a good run T.C.
                    I just put in a MG motor and esc and will try a X642 on mine, I hope this weekend..
                    • Steven Vaccaro
                      • 8721
                      Setting up a mm lso myself, how did this ever end up?
                      • T.C.
                        • Sep 2009
                        • 236
                        Hope to try it this weekend?
                        T.C.
                          My MM works best with the AQ1800 Kv motor and an m445 prop. CG is at ~29% and prop is about 1/4" above the sponsons and angled up a couple degrees at the prop end. The BJ motor was too low in Kv and the UL-1 overheated with any decent prop or speed.
