Toppower 4082 bearings
  • Mel279
    • Dec 2008
    • 857
    hi
    I need help if any of you guys here knows the bearings size for toppower motor, I think its similar to leopard 4082 motor. I want to upgrade using ceramic bearings just to be on the safe side. It for my twin 6s setup.
  • m4a1usr
    Fast Electric Addict
    • 2038
    Originally posted by Mel279
    hi
    I dont own a 4082 but it appears they have the same end caps as a 4074 motor. And if thats the case the 4074 motors use a 625zz bearing. Now the Keda 4074 motors do not use the same size bearings as the Leopards/TopPower/Tacons. The Keda 4074 uses 605ZZ bearings. Maybe someone has popped open their 4082 and will chime in to confirm.
    John
    Change is the one Constant
    • Mel279
      • Dec 2008
      • 857
      m4a1usr
      I have checked the bearing on the end cap, its totally the same as the leopard which is 625z NSK Indonesia. Anyway thanks alot for your reply. cheers
      • Mel279
        • Dec 2008
        • 857
        Does anyone know the timing setting on seaking 180A for a 4082 4-poles 1600kv motor?its setup for 6s.
