Universal joint
  • pribco
    • Feb 2011
    • 109
    Universal joint
    Am in the process of tacking in the stuffing box, drive shaft and motor mount in the Skidaddle Too I am making.
    Am using universal joint BC17 from Offshore.
    When doing this how important is "up and down" alighnment"? I suspect "back and forth" should be spot on, but am wondering if slight motor "slant" id OK?
    Am not looking for great speed.
    Bill
    If you step on my tail, you had best make plans to deal with my teeth!!!
  • blizard05
    • Jun 2007
    • 576
    [QUOTE=pribco;299511]Am in the process of tacking in the stuffing box, drive shaft and motor mount in the Skidaddle Too I am making.
    Bill[/QUOTE Keep the alignment "spot on" Are you using a straight shaft? I used a strut mounted to transom, the st tube is tight to bottom of boat(out side) also used a flex shaft with rudder on rt side . Larry
    America home of the free, thanks to the brave [/url]
