Eagle tree quest ?
  • dasboata
    • Dec 2010
    • 3152
    Eagle tree quest ?
    I just purchased the v4 data logger 100amp My question is if we use 180-200 A ESC why do they make a logger with such low amperage ??
  • electric
    • May 2008
    • 1744
    They do make a 150amp version. That is the one I use and it is recording peaks that are the 170amp range with no problems...
    • Basstronics
      • Jun 2008
      • 2345
      Same here.
      You bought to low. Buy the 150 amp version.
      • dasboata
        • Dec 2010
        • 3152
        Originally posted by Basstronics
        Same here.
        I know ,,,Steve was nice enough to refund my $$ I will buy the 150 A when it comes in but still these ECS are 180-200 Amp ????
        • oscarel
          • Dec 2009
          • 2127
          You can also get the USB ones that have a 300 amp expansion module as well.
          • keithbradley
            • 3663
            Keep in mind the castle ICE series controllers serve as data loggers themselves. I had a 160HV that I used to use for setting up my boats, worked very well.
            www.keithbradleyboats.com
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 989
              I have the Eagle Tree 150amp and mine records up to 180 amps without any problems.
              IMO. If you are pulling over 180 amps average you should consider reconfiguring your power system (i.e. buying a lower KV motor and upping your voltage. )
              What voltage are you running and what motor?
